Results 1 to 12 of 12
Thread: Asssitance needed
11th Apr 2020, 03:58 PM #1
Asssitance needed
I just finished boring a depression in the front of a fly fishing reel frame to accept a bezeled agate line guard. It prevents the line from cutting the soft aluminium frame pillars.
Anyway, I noticed movement in milling attachment, cross slide and the saddle. The movement was due to up directional forces as the cutter came up against the frame. I tightened up the gib in the cross slide which eliminated that some small movement in the cross slide but was still apparent on the saddle over the ways.
have a look at the pictures and you can see that my boring wasn't what is normally done on the lathe.
But I'm wondering if there's some sort of adjustment I can make to hold the saddle down to stay on the ways?
Any suggestions appreciated.
11th Apr 2020, 04:01 PM #2
Here's the milling attachment so you can see it.
11th Apr 2020, 04:11 PM #3Member
- Feb 2014
- Newcastle NSW
- 78
Would locking the carriage down with the square bolt on the carriage help?
11th Apr 2020, 06:15 PM #4Most Valued Member
- 4,890
At the back of the saddle there is a keeper plate with either 2 bolts or 2 set screws, if you loosen the bolts/ set screws a little you would be able to insert a shim between the keeper and the underside of the bed way, once a suitable size shim is inserted you can then tighten the bolts/ set screws and secure the bed in position, this will stop the saddle raising but will also stop you from being able to move the saddle whilst machining.
11th Apr 2020, 06:29 PM #5
The square bolt at the front I know and use it when parting.
I also know about the plate at the back. But as you say, Pipeclay, I need to bring the work piece up to the spindle so I just wondered if there was anything I have over looked or that I wasn't aware of.
But thanks, Zumanity and Pipeclay.
I guess I might just need to get myself a dedicated mill.
Oh, I hasten to add, the job was successful. Just like a the smaller version factory made reel from Hardy's.
11th Apr 2020, 10:37 PM #6Senior Member
- gold coast
- 303
What a refreshing moment to see such a pretty self made reel.
Its so easy to buy something from china, which works very well in spooling up a fly line, and often has quite adequate drag, BUT, there's nothing purist in that!
12th Apr 2020, 12:34 AM #7
Hi Boris,
There should be some means of adjusting the saddle for wear in the shears. The saddle will get tighter/harder to move as you get towards the tailstock. Are there any shims or adjustment in the retaining plates at the front or back of the saddle, or both ?Best Regards:
12th Apr 2020, 08:08 AM #8
Brian, I'm sorry to disappoint you, I didn't make that reel. It's a vintage reel made by Hardy when they still made reels in England.
It's a model called "Perfect" mark II and on some of those they didn't add agate line guards. Since I had a spare genuine line guard I decided I'd learn a few reel making skills by fitting it to the reel.
My long term aim is to make a reel from scratch but in the meantime I thought I'd acquire some know how.
Having said that, I agree with you that a bench made reel would be great. Here's another photo.
12th Apr 2020, 08:14 AM #9
12th Apr 2020, 06:23 PM #10Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
could you mount the real on a face plate?
aaron
12th Apr 2020, 08:12 PM #11
That's a good question, azzrock.
I hadn't thought of that. I have a face plate, but I'd need to marry that with an angle plate to attach the reel on its edge.
12th Apr 2020, 11:32 PM #12Most Valued Member
- Oct 2010
- 1,910
angle plate is one thing. I havent really seen an hercus size angle plate. No doubt there out there. a 123 block might work.
Id be inclined to to try a sold piece of angle iron. maybe even a ubolt.
Help needed
By KBs PensNmore in forum METALWORK GENERALReplies: 2Last Post: 13th Jun 2018, 09:33 PM -
Help needed, PLEASE.
By KBs PensNmore in forum METALWORK GENERALReplies: 4Last Post: 7th May 2018, 05:51 PM -
help needed please.
By danielhobby in forum METALWORK GENERALReplies: 6Last Post: 9th Oct 2013, 11:18 PM -
3/4 Tap and Die Needed - Can you help!
By Milo in forum METALWORK GENERALReplies: 14Last Post: 28th May 2013, 04:21 PM -
Help needed with an AL-54B
By funkychicken in forum METALWORK GENERALReplies: 1Last Post: 26th Mar 2009, 04:46 PM
