Results 1 to 13 of 13
    Feb 2014
    Newcastle NSW
    78
    Default chip tray liner question...
    Hi people, just wondering what you guy's are using (if at all) for a chip tray liner to make cleaning up after a job a little bit easier?
    I was thinking old newspaper lining the tray in 2 layers would hold the chips and oils etc, allowing a simple roll up and disposal of swarf and associated material for disposal. Your tips and advice is very much welcome.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    An old or new baking tray, get hold of a bit of gal sheet or mild about .5 mm or similar,fold the sides up aground about 12/15 mm slip under the bed.
    Try a small Chinese container under the gearbox if required.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    Likewise. No newspaper harmed in this workshop.
    I've made up a tray that fits under the lathe bed and every so often I take it out and dump the swarf in the bin (especially when about to do small parts). I have similar metal tray under the drill press table.
    6,480
    I admit that I'm lazy and don't clean as much as I should, I just use a dust pan and brush after the magnetic wand has done its stuff.
    7,189
    Mine came with a full size tray made out of Zn plate. However I also made up toothless rake out of 150 mm long pice of 25x25 angle that I use to rake up the large swarf and pull out of the tray direct into a rubbish bin.
    Dec 2005
    South Australia
    1,658
    I just use a cheep shopvac $20 from Aldi I consider this expendable it has been going for 2 years
    May 2011
    Murray Bridge S Aust.
    5,959
    Quote Originally Posted by Zumanity View Post
    I think you'll find that if the paper gets too damp, it'll fall apart and end up with a greater mess to clean up.
    Mar 2009
    54
    825
    I've lined the tray of my lathe with some industrial lino. I use a magnetic wand for cleanup and the lino prevents it from sticking to the tray. Unlike the tray whose paint is all chipped the Lino is very smooth so any swarf the wand can't or doesn't pick up sweeps up very cleanly and easily.
    I also have an old rigid plastic food tray which lives under the business end to catch the bulk of swarf which I can lift out and dump in the scrap bin directly. When not in use a half dozen or so pages of newspaper is left on the tray to soak up any oil drips, this is removed when in use.
    I also made up a removable cover that clips between the ways under the chuck, this prevents a lot of crap getting under the headstock and simplifies cleaning.
    The industrial lino is around 3mm thick and very durable, it's been there for six years and shows no sign of degradation despite have been covered in plenty of oil and very hot blue swarf. The tray has been there for ten years and is the same.
    Greg.
    Oct 2010
    melbourne, laverton
    1,910
    stubbie lids.
    Feb 2014
    Newcastle NSW
    78
    Thanks guys! All excellent ideas and gives me plenty of options to consider
    Nov 2018
    Tasmania
    97
    I've taken to a simple approach, it's not perfect but it makes it easier
    I place a board of plywood under the lathe and it catches most of the chips
    Extra benefit is it can only hold so much so you have to empty it rather than let it sit
    7,189
    Not sure ply is such a good idea IF water soluble coolant is used especially it’s left that way even ON
    Nov 2018
    Tasmania
    97
    Good point.
    When I apply water soluble oil it is with a brush. Would not recommend flood/spray coolant
    My scrappy board is still going strong 2 years on, just stained and a bit saggy!
  1. .22 barrel liner
    By .RC. in forum GUNSMITHING
    Last Post: 24th Sep 2016, 06:53 PM
  2. quick fix trailer liner
    By rusel in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 15th Jul 2016, 03:56 AM
  3. teflon liner in bulk?
    By danielhobby in forum WELDING
    Last Post: 16th Feb 2014, 08:23 AM
  4. Shaper Chip question
    By Ueee in forum METALWORK GENERAL
    Last Post: 10th Jul 2012, 01:41 AM
  5. where to get ute liner paint
    By Gaza in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 16th Mar 2012, 09:28 PM
