Page 4 of 4 FirstFirst 1234
Results 46 to 49 of 49
  1. #46
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by Metalmachine View Post
    I don't think I'd go down this next road, it just dosen't feel right, but I noticed that Penrite Hydraulic Jack oil is ISO 45..
    That what I use for all lubrication on my Hercus 260. Lots of it.
  2. #47
    34
    1,080
    Bit late to the party, but we use Hyspin 68 AWS on everything with the old machines at work with no issues; even a 2000 RPM Swiss hobbing spindle with tapered plain bearings that the book says should get ISO 15.
  3. #48
    Jan 2014
    Perth, Western Australia
    18
    Default Headstock bearing lubrication system - AR9
    A question please for everyone about the intended function of the AR9 headstock roller bearing lubrication system.
    The diagram below is a cross section of the outboard bearing of a 260, but the lubrication arrangement is the same as my AR9.
    Oil is introduced via the oilers to location 'A'. It finds its way to the outboard side of the bearing 'D' via drilled holes 'B' and a small relief 'C' at the 6 o'clock position in the bearing cap casting 107. The oil level at 'A' and 'D' are then the same.
    To my question then: Unless the bearing cap 107 metal-to-metal seal at 'E' is pretty good, the oil will simply drain away at 'E'. This is what mine does within a day or so. Is this what the designer intended?
    Mine has no gasket under the bearing caps and no such item appears in the Spare Parts Manual indicating that gaskets were not intended by the designer.
    I'm considering installing a paper gasket to slow the loss.
    What are members' thoughts and experience please. Thanks All.
  4. #49
    Oct 2019
    Adelaide, SA
    1,226
    Default A thread about oil. With a question.
    Older lathes were designed for a total loss lubrication system and there is no intention in the design to retain the oil.
    With all due respect: these old girls love to leak
    The oil also helps moving debris away from precision surfaces. In some cases a pressurized oil gun is required to flush oil through the nozzles into the groves till we actually see oil starting to move/drip.
    On my Myford S7 every time I life the cover I see a small puddle under the headstock.
    I just oil when I need to run the lathe and after I am done. If not in use which has been fairly rare for a month to go by, I just put a few drops here n there for safe measure.
    Some people have designed their own 1-shot oil system for their lathes but I find doesn’t really solve the problem of leakage.
  1. Another old thread question.
    By A Duke in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 23rd Sep 2013, 11:34 AM
  2. New Guy with Question
    By Shovelfreak in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 9th Mar 2011, 11:00 PM
  3. lathe thread question
    By turbo TA in forum METALWORK GENERAL
    Last Post: 28th Aug 2009, 10:06 AM
