Results 16 to 21 of 21
17th Jan 2020, 09:15 AM #16Golden Member
- Sep 2009
- 666
What’s a good jack shaft axle diameter? I was thinking 16-18mm. My plan was to tension the belts with the weight of the motor. Plus I want the pulleys to use the shaft and rotate on it.
I want minimal deflection but don’t want to over engineer it either.
17th Jan 2020, 10:14 AM #17Gear expert in training
- 34
- 1,080
Just checked and I can index 127 teeth no problem, you'll have to confirm the tooth pitch and angle but we do have an 18DP 14 1/2 degree hob
17th Jan 2020, 10:24 AM #18Member: Blue and white apron brigade
Wood cutting bandsaws typically have two speeds 500 and 1000 m/min. Optimum speeds for cutting wood are 1500 m/min but this is pretty scary and also heats the band up so that in some cases like long cuts band cooling is required (on the Bandsaw mill I sometimes use we use water).
The 4 pole 3HP WW bandsaw in my shed with non-vector drive VFD can run up to 1500 m/min (75 Hz) and theoretically down to zero. I don't worry about slow speeds because the motor has an independent 2x motor speed fan on it. I don't use the 1500 m/min often but for ripping short (~500mm long) logs it saves time and does not overheat too much in this length of cut.
At 50Hz my BS runs 1000 m/min, so at 17Hz it's still able to generate ~1HP and 340 m/min which is still way too fast for steel but works fine for Al - I have not been able to stall the band at this speed in small pieces but it will gall if pushed. In fact I can cut the Al on 1000 m/min and often do that, but for thick pieces some form of lube (wax) is required to prevent galling. Interestingly on my WW circular (1200 m/min) with the composite (negative raked) blade I rarely use lube.
If 30 m/min is the max needed for steel and 1000 m/m is needed for timber this suggests a 33:1 range overall might suffice
If a vector drive VFD is used then at 17Hz I would expect at least half the motor power to be available but if the motor power is doubled then original power could be had at the same speed. Then if the top speed is engineered to occur at say 100 Hz that would provide a ratio of ~6:1 in working speed.
Then, based on the 33:1 range required, the 6:1 obtained via the VFD suggest about a 5:1 pulley is all that is needed on the BS itself.
This is of course cutting it fine, and it would be nice to operate say from say 10 m/min to say 1200 m/min (120:1)
If 6:1 can be obtained by the VFD this leaves 20:1 to be obtained mechanically, so perhaps a 4:1 and a 5:1 pairs of pulleys would do that?.
Using a non vector drive VFD with a double HP motor will give original power from 25Hz up, to say 100 Hz or a 4:1
To get 120:1 then requires 30:1 mechanically which starts to get tricky but not impossible.
Alternatively if one is happy enough to work overall with a 33:1, then with 4:1 from a non-vector drive VFD, means only ~8:1 is needed mechanically.
Lots of options.
17th Jan 2020, 10:48 AM #19Member: Blue and white apron brigade
FWIW I just remembered the Steelfast upright metal cutting BS in the mens shed starts out like the Woodfast, but it has a 5 pulley pairs that generate up to a 20:1? reduction.
Its usually left on the middle (10:1?) pulley pair (sorry don't know what this means in m/min) and it's used to cut curves in thin steel metal and Al sections.
For HD cuts a power hacksaw is used.
17th Jan 2020, 11:57 AM #20Golden Member
- Nov 2010
- Gippsland Victoria
- 733
63 teeth the current minimum.
Depending upon what other spur gears you have and what ratios are in your gearbox you might be able to lower that a bit further
Have seen people discussing 21 , 31, 32, 33, 34, as being helpful for cutting metric on old myford lathes - again this would depend upon your current spur gears and gearbox ratios.
A forum member called VernonV wrote a terrific calculator called Lathegears for calculating all possible gear trains given your leadscrew TPI, gearbox ratios and required output thread, well worth a look and a download.
Bill
24th Feb 2020, 03:14 PM #21Novice
- Jan 2014
- Perth, Western Australia
- 18
In relation to the 63 tooth gear for this purpose, note that 63=3 x 21.
If the appropriate additional gears are available to give the 3:1 ratio, a 21 tooth gear will also work in place of the 63.
Here are some numbers for those who might be interested in the maths (with the detailed working):
The required exact ratio is achieved by use of a compound gear set of 127/100 (i.e. 1.27) which is very closely approximated by 80/63 = 1.269841, just 1 in 8001 smaller.
The 63 tooth gear can be replaced with a 21 tooth gear. For example, a 1 mm pitch from an 8 tpi lead screw requires a
lead screw to spindle ratio of 8/25.4 = 80/(127 * 2) = (100/127)*(80/200) =(approx) (63/80)*(80/200) = 63/200 = (21/40)*(30/50).
Sunderland gear cutters and cutters
By Somedayplumbing in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 2Last Post: 28th Aug 2019, 10:34 PM -
Gear cutters anyone?
By Michael G in forum METALWORK GENERALReplies: 1Last Post: 30th Apr 2013, 08:56 PM -
Steering gear cutters?
By Ash240 in forum METALWORK GENERALReplies: 6Last Post: 24th May 2012, 09:53 AM -
Holding gear cutters?
By nadroj in forum METALWORK GENERALReplies: 4Last Post: 5th Jun 2011, 11:25 PM -
Metric transposing gear
By Pete F in forum THE HERCUS AREAReplies: 12Last Post: 8th Apr 2011, 01:31 AM
