Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Aug 2019
    Revesby - Sydney Australia
    57
    1,195
    Default Mounted the sensor today
    Some flat bar and an old bracket:
    Just clears the feed tumbler, back gear lever, and change gear cover!
  2. #17
    Feb 2020
    55
    Quote Originally Posted by nigelpearson View Post
    ....... but I gotta work out a power supply
    (this lathe motor is 3phase without a neutral, so local 240v transformer is a challenge)
    I may be a bit wrong in the head, but aren't there 4 wires running from your 3 phase plug?
    If there are, one of them will be neutral and the other 3 will be entirely conventional 240VAC supplies, with only phase timing differentiating them from each other.
  3. #18
    Aug 2019
    57
    1,195
    Not wrong in the head, just slightly incorrect from a safety point of view.
    Here are the three phase cabling options in a convenient table of increasing safety:
    # wires cable type use comment
    3 rubber
    red/black/white
    Non-earthed 3 ø. Rare. Old. UNSAFE*
    4 4C Non-earthed 3 ø with neutral UNSAFE*
    4 3C+E Earthed 3 ø. Delta-wired motors Motor vibration
    5 4C+E Earthed 3 ø with neutral. Star-wired motors
    * I suspect that any form of non-bonded three phase, even if double-insulated, is illegal in Australia?
    My Hercus is currently connected 3C+E.
    My 3 phase circuits have no safety switch, so I could break the law and use the earth wire as a low current neutral for a small transformer or PSU, but I think it creates earth potential problems.
    (there is meant to be only one bond from the property's earth to the neutral link, at the main switchboard or fusebox. If you draw any current between earth and any of the phases, it creates a voltage between the earths in that property, which creates a potential shock situation)
  4. #19
    Feb 2020
    55
    Thanks for clearing that up. I forgot the earth.
  1. Hercus #3A or #1 T&C smaller wheel guard and Hercus #3A wheel shaft pulley.
    By lamestllama in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 30th Aug 2019, 12:01 PM
  2. Huanyang 24v line and tachometer
    By TheNutter in forum METALWORK GENERAL
    Last Post: 13th Aug 2015, 10:31 PM
  3. Tachometer
    By nearnexus in forum METALWORK GENERAL
    Last Post: 17th Feb 2014, 09:56 PM
  4. Hercus 9" vs hercus 260 ????????
    By bitza500 in forum THE HERCUS AREA
    Last Post: 26th Jun 2009, 10:50 PM
  5. Hercus parts on Ebay from Hercus
    By bollie7 in forum THE HERCUS AREA
    Last Post: 8th Oct 2008, 02:59 PM
