Results 16 to 19 of 19
Thread: Tachometer on Hercus 9C
2nd Apr 2020, 06:09 PM #16Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,185
Mounted the sensor today
Some flat bar and an old bracket:
Just clears the feed tumbler, back gear lever, and change gear cover!
2nd May 2020, 01:35 AM #17
2nd May 2020, 08:44 AM #18Diamond Member
- Aug 2019
- 56
- 1,185
Not wrong in the head, just slightly incorrect from a safety point of view.
Here are the three phase cabling options in a convenient table of increasing safety:
# wires cable type use comment 3 rubber
red/black/whiteNon-earthed 3 ø. Rare. Old. UNSAFE* 4 4C Non-earthed 3 ø with neutral UNSAFE* 4 3C+E Earthed 3 ø. Delta-wired motors Motor vibration 5 4C+E Earthed 3 ø with neutral. Star-wired motors
* I suspect that any form of non-bonded three phase, even if double-insulated, is illegal in Australia?
My Hercus is currently connected 3C+E.
My 3 phase circuits have no safety switch, so I could break the law and use the earth wire as a low current neutral for a small transformer or PSU, but I think it creates earth potential problems.
(there is meant to be only one bond from the property's earth to the neutral link, at the main switchboard or fusebox. If you draw any current between earth and any of the phases, it creates a voltage between the earths in that property, which creates a potential shock situation)
2nd May 2020, 10:55 PM #19
Thanks for clearing that up. I forgot the earth.
Hercus #3A or #1 T&C smaller wheel guard and Hercus #3A wheel shaft pulley.
By lamestllama in forum METALWORK - Machinery, Equipment, MARKETReplies: 8Last Post: 30th Aug 2019, 12:01 PM -
Huanyang 24v line and tachometer
By TheNutter in forum METALWORK GENERALReplies: 17Last Post: 13th Aug 2015, 10:31 PM -
Tachometer
By nearnexus in forum METALWORK GENERALReplies: 16Last Post: 17th Feb 2014, 09:56 PM -
Hercus 9" vs hercus 260 ????????
By bitza500 in forum THE HERCUS AREAReplies: 1Last Post: 26th Jun 2009, 10:50 PM -
Hercus parts on Ebay from Hercus
By bollie7 in forum THE HERCUS AREAReplies: 0Last Post: 8th Oct 2008, 02:59 PM
