Results 1 to 11 of 11
    Dec 2019
    Narangba Australia
    76
    7
    Default Hercus Milling Machine Collet Assembly
    Hi,
    Can any one tell me how the collet holder is removed from the vertical head? I thought it just knocked out by inserting a drift from the top and giving it a tap. Is that correct.
    Cheers.
    Bill.
    Oct 2004
    Southern Highlands NSW
    1,898
    If the accessory has a Morse taper with no thread on the end, tapping with a plain drift should be OK.
    But if it has a female thread on the end for tightening with a threaded bar, the normal way would be to unscrew the bar a bit, and then tap the top of it with a hammer.
    To use a drift where there's a thread on the accessory risks damaging the thread.
    Dec 2019
    Narangba Australia
    76
    7
    Default Hurcus Collet
    Hi Nadroj,
    It is not the morse taper or the collet I am trying to remove, but the collet holder that the collets tighten up in, so the morse taper can then fit in.
    Cheers.
    Bill.
    Quote Originally Posted by nadroj View Post
    Oct 2004
    1,898
    I think that generally if there is no thread or other feature that could be damaged by drifting, then it's probably OK to do that.
    What type of collets do you use?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Is it the Vertical spindle that you want to remove, if so you will need to disassemble the Vertical head.
    6,480
    Does the collet fit into the Morse taper socket that is part of and machined into the spindle ?
    Feb 2009
    jilliby nsw
    111
    My hercus mill has a piece that fits the morse taper and the collets fit into this and is tightened by a drawbar. That slides down the inner part of the vertical head spindle. To get it apart first unscrew drawbar and remove it and the collet. To get the collet/ MT3 adapter out I slide a piece of 5/8 bar down the spindle and tap with a hammer. I hav found if you tighten the collet excessively then this adapter is really difficult to loosen. It will only come out with the aid of a bigger hammer! Hope this answers your question
    Dec 2019
    Narangba Australia
    76
    7
    Quote Originally Posted by hpa1 View Post
    Hi hpa1,
    Thanks for the reply. I was pretty sure that was what I did but it was quite awhile ago and I didn't want to damage anything.
    Cheers.
    Bill.
    Dec 2019
    Narangba Australia
    76
    7
    Default Collet holder
    Many thanks to those who replied to my post.
    Christmas cheers.
    Bill.
    Mar 2017
    Sydney between denial & paranoia
    88
    Don't forget to use a "brass" bar!!
    Good luck.
    Oct 2004
    1,898
    Nothing wrong with brass, but the plain bar supplied with my small Emco mill-drill as new is steel.
  1. Hercus milling machine mk 1 & 2
    By Zsteve in forum THE HERCUS AREA
    Last Post: 27th Feb 2021, 06:16 PM
  2. Hercus Milling Machine for Sale
    By bwal74 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 3rd Jul 2018, 05:20 AM
  3. Hercus dividing head for milling machine
    By wm460 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 23rd Nov 2016, 07:37 PM
  4. Milling Machine from Hercus
    By localele in forum THE HERCUS AREA
    Last Post: 18th Feb 2012, 06:47 AM
  5. Hercus No 2 Milling Machine Manuals
    By geoffd68 in forum THE HERCUS AREA
    Last Post: 16th Oct 2008, 08:35 PM
