Results 1 to 6 of 6
Thread: Hercus 9 QCTP
    Mar 2011
    Southern Flinders Ranges
    1,536
    Default Hercus 9 QCTP
    Greetings Everyone
    Before I go and spend an amount equivalent to the GDP of most small island nations on quick change stuff for my 9” would someone from the brains trust here mind confirming that the 100 series AXA is the correct size for that machine.
    Based on some other threads I’ve seen here I’m going to go to Aussee Machine, example linked below.
    https://www.ausee.com.au/shop/item.aspx?itemid=4249
    Mar 2017
    64
    221
    This is what I've got on mine. Cheers, Tony
    Sent from my SM-G920I using Tapatalk
    Nov 2015
    Brisbane Australia
    85
    Maybe look on this page, he sells similar products.
    AXA Series Wedge Quick Change Tool Post Set ,Up to12"_Machine Tool Access._M&G Productions
    FWIW the knurling tool isn't great on a Hercus, you will be better with a scissor type knurling tool as the machines are too light to make it work correctly.
    He also sells just the tool post and other holders by themselves., I might have 12 holders
    Mar 2017
    64
    221
    Quote Originally Posted by Somedayplumbing View Post
    Agree with that. The scissor type knurling tool is much better. A handful of straight holders are worth buying. You never seem to have enough.
    Mar 2011
    1,536
    Quote Originally Posted by Silversprings View Post
    Thanks for the help everyone, much appreciated. My plan is to buy a tool post and probably somewhere in the vicinity of 30 general purpose holders, and maybe 5 boring bar holders. I can probably fill somewhere around 20 of them straight up and have a few for expansion. Having just got the lathe out storage having had a forced hiatus from it for a while I’m keen to get organised. I’ll post up some pictures when I get more organised.
    6,439
    Hi racingtadpole,
    Whilst I am not against QCTP, I am an advocate of build your own ! For commercial use I would completely agree with you, but not for hobby use ! Too expensive, you are just swapping cost for time. Plus there is the satisfaction of having made it yourself.
    My personal one and the one I use is the "Norman" patent tool holder.
    This first picture is the latest "Norman" tool post and is of my rear parting tool held in a split clamp. The last two pictures are the normal front tool holder. I've now three of these, but I find that it is so versatile I haven't needed to make any more.
  1. qctp
    By shaper07 in forum THE HERCUS AREA
    Last Post: 17th Jan 2019, 10:29 AM
  2. QCTP for Hercus 9
    By joe88 in forum WANTED TO BUY
    Last Post: 16th Oct 2016, 02:55 AM
  3. Aloris AXA QCTP or Chinese copy for Hercus 260?
    By ventureoverland in forum METALWORK GENERAL
    Last Post: 22nd May 2014, 11:42 PM
  4. Qctp
    By jack620 in forum METALWORK GENERAL
    Last Post: 13th Apr 2013, 11:35 AM
  5. QCTP to suit Hercus 9"
    By Pete F in forum THE HERCUS AREA
    Last Post: 10th Dec 2008, 08:26 AM
