Results 16 to 30 of 45
  1. #16
    34
    1,080
    Short of knowing someone with a profile projector that can check the angle for you
    I can do that if you're in Melbourne.
  2. #17
    May 2016
    AU
    30
    I got a bit of quality shed time in last night and managed to knock up a copy of the feed screw for threading. Had to sharpen the cold chisel a couple of times. I'll probably try a test run on another shaft before I tackle this one.
    Anyone know the thread size on the handle end? I don't think it's metric according to my thread gauges.
    I am in Melbourne too, and thanks for the offer. I think I'll wing and see how I go.
    For some reason I'm getting signed in on this forum with the details from another tapatalk forum, so I've lost my history and location details....
    Martin
    Sent from my H4133 using Tapatalk
  3. #18
    Nov 2015
    Brisbane Australia
    85
    Quote Originally Posted by m.j.bower.69 View Post
    Martin
    So was it trapezoidal or Acme?
    What steel did you use and how did you cut the threads, i.e. one tool to the shape/ profile or did you use a tool to hog out the majority then cut the two edges?
  4. #19
    May 2016
    AU
    30
    I haven't cut the threads yet, just turned a blank. Hopefully I'll get some time this weekend.
    I'll single point it, light cuts to sneak up on final size, using the feed nut to test. I have an acme hss tool so I'll check that in the 'old' screw and hone it to a decent fit.
    Martin
  5. #20
    May 2016
    AU
    30
    Oh, and I'm using 1214 free machining steel.
    Martin
  6. #21
    Sep 2011
    Ballarat
    65
    3,103
    Hi Martin
    in your pic, is the thread on the right side of your machined blank the one you are copying?
    It looks (from the pic) to be a square thread.
    Phil
  7. #22
    Jan 2009
    Holbrook, NSW
    73
    490
    Finally getting around to doing something about the slightly bent screw on my metric Hercus. Can anyone confirm whether the screw is trapezoidal or acme?
    The dials say 2mm per revolution.
    And a source for threaded rod, or am I going to have to make it?
    Cheers, Martin
    Hi Martin,
    It is definitely 2mm pitch acme thread on an imperial shaft. Turn the threaded section dia to an undersized 3/8 at .371". Pretty much every metric drive screw in a Hercus is acme thread form. You can take this as Gospel as it comes from original Hercus drawings.
    Mal
  8. #23
    May 2016
    AU
    30
    Thanks Mal.
    I had a suspicion that there was something NQR about the threads on these metric Hercus 9s. I probably read it in one of your threads somewhere.
    Can you confirm what the thread is on the other end? Grateful for your assistance.
    Martin
  9. #24
    Jan 2009
    Holbrook, NSW
    73
    490
    Thanks Mal.
    Martin
    7/32 whitworth
  10. #25
    May 2016
    AU
    30
    Okay, I might make a new nut in metric. I don't have any whitworth dies.
    Martin
  11. #26
    6,480
    Hi M.J,
    Single point it on the lathe !
  12. #27
    Nov 2010
    Frankston south
    102
    I'll lend you one if you're in Melbourne.
  13. #28
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    ... I might make a new nut in metric. I don't have any whitworth dies.
    When repairing old machines, do your best not to mix fastener types - it really creates headaches later on, either because it degrades the machine (I once had a 1/2" UNC thread fitted where it should have been 1/2" BSW - pity about the tpi being different...) or will cause confusion for the next person that has to repair/ replace something.
    Taps and dies can usually be borrowed if you don't want to buy them (although that too is part of the rabbit hole experience)
  14. #29
    6,480
    I've got to agree with Michael, the Taiwanese bandsaw that I've recently acquired, has a mix of metric, BSF and Whit screws and bolts.
  15. #30
    May 2016
    AU
    30
    I get where you're coming from. My view is that firstly the lathe is a tool, and I want it to work. If that means making changes so that it works for me and I can fix it, then I will.
    That said, the original screw and nut will be kept with the lathe and if I sell it, the new owner will be able to return it to original condition if they want.
    Plus I'm talking about a nut that has a slot head. It won't require a different tool from stock to remove.
    I did actually inherit some English dies from my uncle. I'll look through them to see what I've got. How do I identify a whitworth die?
    Martin
  1. I think i damaged my compound..........
    By Zumanity in forum THE HERCUS AREA
    Last Post: 5th Aug 2019, 05:35 PM
  2. Replacing the CVA compound
    By caskwarrior in forum METALWORK PROJECTS
    Last Post: 18th Oct 2018, 08:47 PM
  3. What grade steel for cross/ compound screw
    By monchochos in forum THE HERCUS AREA
    Last Post: 10th Aug 2018, 08:04 AM
  4. Compound Gears
    By Tiptoeturtle in forum THE HERCUS AREA
    Last Post: 4th Feb 2014, 10:07 AM
  5. Removing a Sheraton compound feed screw
    By coffeefro in forum METALWORK GENERAL
    Last Post: 3rd Oct 2011, 09:42 PM
