Results 1 to 5 of 5
31st Jul 2019, 07:51 PM #1Member
- Feb 2014
- Newcastle NSW
- 78
I think i damaged my compound..........
Hi people.
I attempted parting off a piece of mild steel a while back with my C model Hercus and recently went to face off a bit of round stock and can't seem to get a good finish or seem to be able to center the bit properly. It almost feels like the thread in the compound is bent in that area. Any suggestions and advice on what to look for is most welcome!
31st Jul 2019, 08:36 PM #2Senior Member
- Feb 2009
- jilliby nsw
- 111
seems you may have 3 issues there. Surface finish is related to tool shape, sharpening and cutting speed of material, packing the tool bit / holder with thin packing strips may be needed to get cutting edge of tool bit on centre. Use an offcut and face the end off and keep adding / subtracting packing until you get no tit in the centre. And with the compound, unwind fully to expose the threaded rod and check it for straightness with a straight edge and check dovetail slides for burrs or damage if it doesn't slide freely. Normally hercus stuff is fairly robust and it really takes a major incident to result in damage. Good luck with sorting the problem out
31st Jul 2019, 08:44 PM #3Philomath in training
- 6,559
If you had bent the screw, you would notice a cyclic tight spot when turning the handle.
Have you checked your gibs are properly adjusted?
1st Aug 2019, 10:29 AM #4Most Valued Member
- Australia east coast
- 2,713
How are you going to bend a screw captured between slides without massively flexing the compound top slide first? Which, being cast iron & relatively thin, would snap long before you got to the plastic deformation point of the internal screw....
I'd look elsewhere for the problem - loose gibs perhaps.
PDW
5th Aug 2019, 05:35 PM #5Member
- Nov 2018
- Tasmania
- 97
Check your gib screws, I'd say they have come loose
It's surprising how quickly a bit of chatter can loosen them
Damaged motor reversing drum switch
By Flo in forum ELECTRICALSReplies: 7Last Post: 14th Jun 2019, 09:58 PM -
Has any body got a damaged PA MultiTool?
By Grahame Collins in forum METALWORK GENERALReplies: 2Last Post: 21st Feb 2019, 09:00 AM -
Repairing Damaged Thread
By grunto in forum METALWORK GENERALReplies: 51Last Post: 8th Oct 2015, 02:09 PM -
Oops! May have damaged something!
By bwal74 in forum THE HERCUS AREAReplies: 11Last Post: 30th Sep 2012, 06:33 PM -
Building a Trailer from Damaged caravan
By StrathfieldMens in forum TRAILERS & OTHER FABRICATED STUFFReplies: 11Last Post: 12th Jan 2010, 09:17 AM
