Results 1 to 7 of 7
4th Jul 2019, 12:33 PM #1.
- 6,458
Controlled Creeping - Adjustable X Axis Table Stops for the O and 1
I have often thought a pair of adjustable stops would be useful on both the No.O mill and the No.1 tool and cutter grinder. Years ago I made a couple of stops for the Y axis on my other mill so it was only a matter of changing the scale to suit the Hercus'.
I had been my intention to make one pair that were interchangeable between both machines given that they share similar but not identical tee slots. A slightly oversize cross drilled hole through the "tee" bolt would accommodate the difference in the tee slot dimensions and provide the required interchangeability.
So I made a pair using 7/8" square 1214 for the "nut". They looked OK scalewise on the tool and cutter grinder but were in my mind, a bit too large for the little No.O. So I made another pair, this time from some 20mm square 1214. The 5/16" UNF threaded screws and knurled nuts are also 1214, not my favourite material due to its propensity to rust, but given Hercus used the stuff freely on most of their machines, I decided it wouldn't be out of place. Plus, it's easier to machine than 4140. The 13's adjusters are a combination of 4E cast iron and 4140.
IMG_20190628_093712393.jpg IMG_20190628_093946476.jpg IMG_20190628_101017528.jpg IMG_20190628_101604072.jpg
The fixed stops had me toing and froing. I had toyed with the idea of rounding some of their surfaces but simplicity reigned. I don't think the end results look out of place. The stop on the grinder also serves as one of the three table keep plates required to prevent the table tipping off its ball bearing mount. That stop is 4E, the mill's, 1214.
IMG_20190630_095249332.jpg IMG_20190630_095652553.jpg IMG_20190703_162339133.jpg IMG_20190703_162707820.jpg
The idea of interchangeabity seemed like a worthwhile pursuit but in reality it meant removing the grinder's table end covers, the table swivel fine adjuster and a pair of small travel stop screws from the tee slot. Certainly not as convenient as a pair permanently insitu adjusters.
Bob.
9th Jul 2019, 05:48 AM #2Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
Outstanding.
It's nice to see that there's some things in this world that DC ont change much. Like the beautiful work you do Bob. Plus how shiny your little machines are.
Aaron
9th Jul 2019, 09:07 AM #3Member: Blue and white apron brigade
- 7,183
I've also seen these in the flesh so to speak and can confirm they look every bit as good as the photos.
9th Jul 2019, 11:12 AM #4.
- 6,458
The Original Stops.
Thank you all for the thanks and kind words. They are greatly appreciated.
For context I should have posted the photo below earlier because not everyone would be familiar with the lilttle Hercus mill. The grinder utilises the same sliding stops but the fixed stop is three inches wide with an integral lip behind its top edge.
9th Jul 2019, 11:25 AM #5Novice
- Jul 2019
- Texas
- 15
Those are great pictures.
15th Jul 2019, 10:20 AM #6Golden Member
- Jul 2011
- 837
Anorak Bob, Absolutely brilliant work, ever since I got my little Macson bench surface with the micrometer head stops I have thought an adjustable stop on my Hercus #1 T&C grinder would actually be more useful. I think your implementation is very in keeping with the machine.
Eric
15th Jul 2019, 11:53 AM #7.
- 6,458
Thank you Eric.
I had thought about some form of graduated adjuster but the associated size and complexity made the decision to make a simple adjuster easy. The adjusters shown in Bill's photos in your Macson thread look really neat but they are probably still a bit too large for the Hercus.
Bradford Crofts Adjustable Table ?? Not sure ?? FREE
By John T K in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 15th Jan 2018, 11:23 PM -
An Arduino Controlled Indexer for Rotary Table
By Big Shed in forum METALWORK GENERALReplies: 25Last Post: 7th Jan 2017, 11:01 PM -
Creeping or not to creep
By morrisman in forum METALWORK GENERALReplies: 24Last Post: 13th Sep 2016, 12:53 PM -
DM 45 table stops
By morrisman in forum METALWORK GENERALReplies: 18Last Post: 17th Feb 2012, 05:26 PM -
Vise Stops
By Dave J in forum METALWORK GENERALReplies: 16Last Post: 7th Nov 2010, 11:55 PM
