Results 16 to 26 of 26
2nd Jul 2019, 05:27 PM #16Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
2nd Jul 2019, 06:49 PM #17Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Well you got one up successfully, thanks Bruce.
Do you still want some step-by-step instructions for attaching photos to messages at Metalwork Forums?
Jordan
2nd Jul 2019, 07:44 PM #18Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
2nd Jul 2019, 10:00 PM #19Mechanical Butcher
- Oct 2004
- 1,898
OK Bruce.
Say you want to write some words, then add one photo below your text.
To attach a photo to your message:
- Select "Manage Attachments" below message window.
- Then "Add Files" > "Browse"
- Select a photo from your computer, then it takes you back > "Upload"
- In a window below, you should see a small version of your selected photo. Tick the box on its bottom right, then "Done".
- Your photo filename will appear under "Manage Attachments".
- You can then "Submit Reply" as normal, and the photo will be there after your message.
When you are adept at it, try sending multiple photos.
Note that large photo files will automatically be made smaller, even if you upload a big file.
Hope that works for you.
Jordan
3rd Jul 2019, 01:10 PM #20Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
3rd Jul 2019, 01:32 PM #21Most Valued Member
Bruce,
I'm interested in the cross slide stops. I can't figure out how they work because the indexing attachment is in the way. Can you please post an unobstructed pic of them? I also have a slotted cross slide on my 260.Chris
3rd Jul 2019, 01:51 PM #22
Bruce,
Thank you so much for your efforts to figure out picture posting, and Jordan for helping him. You have so much to share and I really thank you for helping us, much appreciated.
Look forward to more.
3rd Jul 2019, 05:19 PM #23Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Kilohertz & Jack620
Here is a photo of the cross slide stop I made... The stops plate is fastened to the saddle normally where a travelling steady would be fitted (fastened by the 2 existing tapped holes in the saddle) & the other "tongue" for the want of a better word fits into the tee slot in the extended cross slide. Its a very neat push fit & clamped in position, by the screw shown. This "tongue" is free to move back & forward between the 2 roller stops, as the cross slide is moved.
The rollers are then adjusted to suit the required movement & presto, the lathe then becomes like the early Capstan or Turret Lathes, with accurate forward & reverse movements for the cross slide.
This eliminates the need for concentration & an unskilled (or tired) operator can be utilised, just like the early repetitive operations performed on a Capstan or Turret lathe.
I hope this explanation with the photo will be of assistance.
Bruce
3rd Jul 2019, 06:04 PM #24Mechanical Butcher
- Oct 2004
- 1,898
That's a neat gadget, Bruce.
Jordan
3rd Jul 2019, 07:13 PM #25Most Valued Member
Great idea Bruce. That's going to the top of my ToDo list. Do you leave it permanently attached?
4th Jul 2019, 10:29 AM #26Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
A pair of 260AT will be following me home tomorrow, my first Hercus
By Kilohertz in forum THE HERCUS AREAReplies: 53Last Post: 11th Nov 2018, 04:11 PM -
Pair of mic gauges
By BobL in forum METALWORK GENERALReplies: 7Last Post: 12th May 2016, 07:48 PM -
German precision- a pair of Thiels
By Anorak Bob in forum METALWORK GENERALReplies: 34Last Post: 27th Apr 2011, 09:28 AM -
Need a good pair of snippers
By Ricardito in forum METALWORK GENERALReplies: 14Last Post: 28th Feb 2011, 08:04 PM
