Results 1 to 10 of 10
    Jun 2019
    Toowoomba
    6
    Default New Hercus Owner with questions
    G'Day all,
    I have just recently purchased a 1952 A model Hercus.
    It came with cast legs but no chip tray.
    Question is how were the legs originally attached, the ones on mine have only 1 bolt per leg (see pic)
    All the parts on the lathe seem to have been there many many years
    It unfortunately has a few broken bits, possibly from a fall, and found out tonight the back gear is missing a tooth.
    Any assistance or advice it more than welcome as I am new to the world of lathes, previous project was a 1950 Land Rover.
    Look forward to getting into the project.
    Regards,
    Brendan
    IMG20190524111846.jpgIMG20190531155607.jpgIMG20190601200221.jpgIMG20190601200205.jpgIMG20190524111806.jpgIMG20190602173547.jpg
    Oct 2004
    Southern Highlands NSW
    1,898
    Hi Brendan.
    Just a guess, maybe the legs were supplied without holes, to be fitted to the lathe as required.
    Then the owner only drilled one hole in each instead of two, for whatever reason.
    It should be straightforward to add more holes for bolts, shimming as required between lathe feet and the legs.
    Missing teeth on back gears is a common fault, due to rough handling by owners not knowing how to remove chucks safely. I'd look for a good used replacement.
    The platform at the back under the motor is something I've never seen before.
    A tray could be folded up and welded. They usually have angled walls, and in the case of A models, often with extra shaping to clear the gearbox levers.
    Nov 2008
    Perth WA
    6,459
    Hello Brendan,
    Welcome to the Forum. I have a '58 lathe with cast legs. The lathe bed feet are fastened to the legs with a pair of fixings. The legs are tapped to accommodate the fixings.
    Bob.
    Jun 2019
    Toowoomba
    6
    Thankyou for the quick replys,
    Just wondering Bob if the legs on yours has spreaders?
    The feet on the lathe seem to be a little wide so guessing who ever purchased it had to do a bit of DIY assembly
    I will have to try and find some full and detaild pictures of the legs and tray to get an idea of rough size etc.
    Thanks again
    Brendan
    Nov 2008
    Perth WA
    6,459
    There is no spreader Brendan.
    Give me a day or so to move some stuff out of the way and I'll take some photos of the legs and swarf tray. I don't use the lathe very often.
    Bob.
    Jun 2019
    Toowoomba
    6
    Bob.
    Thank you Bob
    It will give me something to look over, I don't think with the way work is at the moment that the lathe will be up and running until probably the end of the year.
    Regards,
    Brendan
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,562
    G'day Brendan
    Some people will put a lathe in back gear and then use a sharp blow or two to unstick a tight chuck. That is usually how they get damaged.
    I guess with respect to your gear, the first question is whether or not you have an oxy set and can braze cast iron. If you can, the easiest thing may be to get a piece of cast iron, file it roughly to tooth shape, braze on and then finish file it. Failing that, you may be able to buy a spare or as a last resort, someone here may be able to cut one for you. I say last resort as it's a fair chunk of material so could cost.
    Added bit: repaired worse damage before
    //metalworkforums.com/f309/t200...16#post1923916 (see second picture down)
    //metalworkforums.com/f65/t1210...44#post1924744
    Nov 2008
    Perth WA
    6,459
    Jun 2019
    Toowoomba
    6
    Hi Michael,
    Thanks for the suggestion, Im going to get one of dads mates to have a look, he has fixed far worse over the years and then I can keep the original backgear. As you show in the link there is far worse out there.
    Hi Bob,
    Thank you very much for the detailed pictures, they will assist me very much so, I think looking at the legs on yours mine might be a different type as on yours the feet face out and on mine the feet face inwards.
    If I take my time and do it right I think I will finish up with a very nice and usable lathe.
    Regards,
    Brendan
    Nov 2007
    melbourne australia
    3,228
    Failing that, you may be able to buy a spare...
    They are available if repairing doesn't work out: https://australianmetalworkinghobbyi...product_id=192
  1. New Hercus owner
    By ratters in forum THE HERCUS AREA
    Last Post: 10th Jan 2015, 09:38 PM
  2. New Hercus Owner
    By Iggsy in forum THE HERCUS AREA
    Last Post: 6th Dec 2011, 01:31 PM
  3. New Hercus owner
    By jamie_c in forum THE HERCUS AREA
    Last Post: 23rd Oct 2009, 01:32 AM
  4. New Hercus Owner
    By Mr Santa in forum THE HERCUS AREA
    Last Post: 16th Apr 2009, 11:19 PM
  5. new C MODEL HERCUS OWNER
    By beetle in forum THE HERCUS AREA
    Last Post: 31st Jul 2008, 12:19 AM
