Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    Jan 2018
    72
    20
    Unhappy Tee Slotted Cross Slide & nut
    I maybe able to supply you with a Tee Slotted Cross Slide but I would need to know before you make your nut if interested price would be under $400.
    Thanks for that, unfortunately my parole officer is limiting my spending on "toys" at the moment so that one will have to go on the back burner for now, but I will keep it in mind.
    The idea of drilling and tapping the existing nut to the larger screw size was partially to save money as well.
    My biggest problem at the moment is the epoxy, apparently the guy at 3M was talking through his hat (according to some of their retailers). I can still get the 3M 1838B/A epoxy in 50 ml kits @ $44.72 + GST per kit, but it is a min order of 6 kits, and 25 days USA.
    The correct epoxy adhesive for Turcite is called Waylock it's not a 3M product. Waylock adhesive is made by Trelleborg, it's very expensive, only available in large quantities and and it is not imported into Australia.
    3M 1838B/A epoxy is apparently the next best thing.
    Guess I'll just keep at it.
    Tex
  2. #17
    Jan 2018
    72
    20
    Smile Turcite application and scraping videos
    For anyone interested in Turcite application and scraping you will find some excellent videos at Vintage machinery.org: https://www.youtube.com/watch?v=olpSKiQRrWo
    And one of my other YouTube machine shop favourites is This Old Tony: https://www.youtube.com/user/featony
    I have learnt a heap of stuff on both those channels.
    Tex.
  3. #18
    Nov 2017
    Geelong, Australia
    53
    741
    From memory the last time I was looking at epoxy availability there were a couple of AU companies making epoxy resins/adhesives.
    Might be worth investigating and having a chat to their tech guys to see if they have an equivalent product. You might even get lucky with getting a sample to play with.
  4. #19
    Jan 2018
    72
    20
    Thumbs up Epoxy
    Couldn't find your post, just realised there is now a second page to this thread, DOH!
    Hi Steve,
    Yes their are actually quite a few, but this stuff has very specific qualities.
    I have made some progress, the guy from 3M is currently investigating an equivalent/replacement for me.
    Tex
  5. #20
    Jan 2018
    72
    20
    Unhappy Baking cast iron
    Ok, I'm a up to the baking of the Cross slide and then sand blasting before I apply the Turcite, anybody got any clues as to the "baking" procedure, duration etc?
    Took a week to get a reply from 3M. Unsatisfactory answer, "Locally stocked 2216 Epoxy might be an alternative. Where the 1838 is rigid the 2216 is more flexible". My understand is flexible is NOT good for this application.
    In the mean time I bought some JB Weld JB 8265-S cold weld 2 part Epoxy Adhesive system on recommendation in one of the forums, think I will go with that. It was cheap on EBay from local supplier.
    Tex
  6. #21
    Nov 2017
    Geelong, Australia
    53
    741
    The only JB Weld I've used is the vanilla flavour that you can get from hardware stores.
    It's been good stuff though and my 7 year old kit is still going strong.
    Hopefully the special brew you've got works even better.
  7. #22
    Jan 2018
    72
    20
    Default JB Weld
    Hi Steve,
    Yep I had a good look at the USA JB Weld site and picked the product which seems to be close to the original stuff, and which is available in Oz.
    Tex
  8. #23
    Jan 2018
    72
    20
    Default 3M Epoxy
    Quote Originally Posted by Tex260Z View Post
    Hi Steve,
    Tex
    So, the 3M Engineer advises that "DP190 is very similar to 1838", it isn't really because 1838 is a paste, and DP190 is a "self leveling liquid".
    I thinks these guys are knobs.
    Oh well, happy days.
    I'll let you know how the JB Weld works out.
  9. #24
    Nov 2017
    Geelong, Australia
    53
    741
    I reckon the 3M guy will just be looking at it's cured mechanical properties which is probably the important part as long - as you can get to that point!
    For applying on turcite you could probably get away with a self leveling type of product as you're just spreading it on both surfaces then putting them together. There won't be any appreciable volume to "flow"
  10. #25
    Jan 2018
    72
    20
    Default Baking, Turcite, epoxy & scraping
    Everything went on the back burner for some months whilst i did an intensive course in building a large LiFePO4 prismatic cell battery and BMS system for the van.
    Anyway I did get as far as epoxying the Turcite to the saddle and scraping it in, it all actually went brilliantly, had to bake the cross slide twice and clean in white spirit to get rid of all the soaked in oils etc.
    Hope to get back to the project next week.
    Tex
  11. #26
    May 2011
    Murray Bridge S Aust.
    67
    4,434
    Hi Guys, Everything went on the back burner for some months whilst i did an intensive course in building a large LiFePO4 prismatic cell battery and BMS system for the van. Cheers Tex
    Sounds an interesting project, is this like a solar panel system???
    Any chance of some pics, PLEASE?
  12. #27
    Jan 2018
    72
    20
    Exclamation This forum?
    Yes I can, but I suspect I might get chastised for putting up pics of my system on this forum?
    Is there somewhere else I can upload that stuff to?
    Tex
  13. #28
    Jan 2018
    72
    20
    Default Epoxy
    Forgot to mention, I used JB Weld epoxy, perfect for the job, readily available.
    Also I remade to groove in the bottom of the saddle vees by hand with a parting tool, eesy peesy.
  14. #29
    Nov 2017
    Geelong, Australia
    53
    741
    Iím assuming you still needed to scrape the Turcite after gluing it on?
  15. #30
    Jan 2018
    72
    20
    Default Scraping Turcite
    Re scraping Turcite, yes definitely needs scraping.
    I put Glad Wrap over the ways and clamped the saddle down very tight, but it still definitely needed scraping.
    I picked up the info on that process here: https://www.youtube.com/watch?v=4k0Ze0Hwvbg
    My job was on vees, and that example is flat, but you can see the read when it's blued up.
    It's certainly easy to "pull" scrape.
  1. Cross Slide Scraping Hercus 260
    By Abratool in forum THE HERCUS AREA
    Last Post: 14th Nov 2014, 05:06 PM
  2. Backlash in Hercus 260 cross-slide
    By jack620 in forum THE HERCUS AREA
    Last Post: 4th Mar 2013, 06:19 PM
  3. Hercus 260 Cross-slide play
    Last Post: 26th Sep 2011, 08:47 PM
  4. South Bend/Hercus Cross slide nut
    By YarrD in forum THE HERCUS AREA
    Last Post: 14th Dec 2010, 11:34 PM
  5. Hercus Extended Cross Slide Casting
    By Swarfmaker1 in forum THE HERCUS AREA
    Last Post: 3rd Dec 2010, 07:18 AM
