Results 1 to 2 of 2
    Oct 2001
    ACT
    667
    Default Hercus milling machine mk 1 & 2
    So seeing a Hercus model 0 Mk2 milling machine on the interweb, there are obvious differences (to a Mk1 ) in that the table has three T slots and the mk2 has a better speed range.
    what other differences are there. are the slide ways longer wider, z axis longer etc? does it still have MT3 arbour?
    not sure if there's any info in the manual (as I don't have one )
    just wondering.
    cheers
    Oct 2001
    ACT
    667
    Default Hercus milling machine Specifications 2 slot and 3 slot machines
    After about three years from my first post above.... I recently got a copy of another Hercus mill manual (recently posted on this forum). I later discovered that this new manual was in fact for the three slot (Mk2) mill .
    So have put together a comparison table.Hercus 2 & 3 slot machines comparison.pdf
    The Mk2 has a slightly bigger (wider and longer table) and more cross slide travel and slightly more z axis travel. Also there was the option to order a 30 international taper instead of the morse #3 advertised for the Mk1 and you can only assume that it was available for the Mk2.
    also a couple of images of the details.
    Mk 1
    Mk 2
  1. Hercus dividing head for milling machine
    By wm460 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 23rd Nov 2016, 07:37 PM
  2. VICTORIA Milling Machine
    By ersbruce in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 5th Jun 2012, 02:14 PM
  3. Used Milling Machine
    By woodfast in forum METALWORK GENERAL
    Last Post: 15th Apr 2012, 10:07 PM
  4. Milling Machine from Hercus
    By localele in forum THE HERCUS AREA
    Last Post: 18th Feb 2012, 06:47 AM
  5. Hercus No 2 Milling Machine Manuals
    By geoffd68 in forum THE HERCUS AREA
    Last Post: 16th Oct 2008, 08:35 PM
