Results 1 to 9 of 9
30th Mar 2016, 07:23 PM #1Member
- Feb 2012
- 61
Moving a Hercus 9" long bed model A
G'day guys,
I'm having to move my workshop once again and I was wondering if anyone had any tricks for moving lathes.
In the past I have dismantles the belts and motor assembly and man handled it into place with one other person. While this works, it is not great on backs.
What are your thoughts on using an engine crane to lift it without dismantling it.
30th Mar 2016, 07:39 PM #2Most Valued Member
- 4,887
Yes that will work.
30th Mar 2016, 08:18 PM #3Pink 10EE owner
- 6,216
If you are not removing it from the base, remember it is very top heavy.
30th Mar 2016, 08:22 PM #4Member
- Feb 2012
- 61
I will remove it from the base, makes in easy get on the ute.
Sent from my SM-P555 using Tapatalk
30th Mar 2016, 08:30 PM #5Golden Member
- Mar 2009
- 54
- 825
Another option is a pallet truck. My workshop is somewhat spaitialy challenged so both my 260 long bed and Thiel mill live on wooden risers so they can be moved quickly and safely this way when necessary.
Greg.
30th Mar 2016, 09:06 PM #6Most Valued Member
- 4,887
Pick it up from around the gusset in front of the spindle, you could probably use that belt as the sling.
1st Apr 2016, 09:32 AM #7Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
I always dismantle a Hercus 9 when moving more than a short distance, either partially or completely.
The way it's made makes it easy to reassemble accurately.
When stripped, the short bed can be lifted fairly easily by myself, but I think I'd prefer a helper to move a long bed.
The drive assembly is fragile and something will likely break if there's a fall.
The carriage assembly can be removed after unscrewing the RH leadscrew bearing and rack.
The gearbox and leadscrew come off as an assembly.
It's all really straightforward, quite fun actually.
These are very well thought out lathes.
1st Apr 2016, 02:22 PM #8Novice
- Mar 2016
- Robertson NSW OZ
- 11
I just moved one with a car hydraulic hoist. From out the back of a Ford transit and into the shed. Short sling Around the bed just in front of the chuck. Bit of trial and error to get a good balance point
10th Apr 2016, 11:39 PM #9Member
- Feb 2012
- 61
Success guys, i got the lathe moved into the new workshop. I ended up hiring an engine hoist for kennards. I took the motor and belt reduction off to transport it and it all went smoothly.
Hercus 9" Model A Nose thread specs.
By Nickon in forum THE HERCUS AREAReplies: 15Last Post: 15th Jun 2015, 12:00 PM -
Moving a Hercus 9" - one man - previous posts
By steamingbill in forum THE HERCUS AREAReplies: 14Last Post: 15th Sep 2013, 11:11 AM -
hercus 9" c model
By tryhard202 in forum THE HERCUS AREAReplies: 1Last Post: 4th Nov 2012, 11:43 PM -
Hercus 9" Model A Feed Nuts
By wannabe in forum THE HERCUS AREAReplies: 2Last Post: 18th Nov 2010, 11:26 AM -
Moving a hercus 9" lathe...one man job?
By Greg Q in forum METALWORK GENERALReplies: 17Last Post: 9th Apr 2008, 03:57 PM
