Results 1 to 14 of 14
Thread: Wanted 3 Jaw Chuck for Hercus 9"
29th Mar 2016, 10:35 AM #1Novice
- Mar 2016
- Robertson NSW OZ
- 11
Hi everyone..
Ive recently bought a Hercus 9" Model C . It came with a 3 Jaw chuck but only with the reverse set of Jaws..
Can someone advise of a part number, Model of 3 Jaw Chuck I can buy for this model
Thanks in advance
Phil
29th Mar 2016, 12:10 PM #2Banned
- Aug 2015
- QLD
- 735
Is there a brand name on the chuck? New jaws may be available for it.
Re new chuck. If your unable to do the thread and diameter measurements just take the chuck to Hare and Forbes and they will help you out with it.
29th Mar 2016, 12:38 PM #3Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Look up Mick Moyle, Summer Hill, Sydney - they have some used chuck jaws.
29th Mar 2016, 01:10 PM #4Golden Member
- Cairns, Q
- 666
If you cannot find a set of replacement jaws for your existing chuck you will probably have to buy a chuck designed for backplate mounting e.g.
Lathe Chuck - 3 Jaw - Backplate | For Sale Sydney Brisbane Melbourne Perth | Buy Workshop Equipment & Machinery online at machineryhouse.com.au
and make or buy a backplate to suit, then fit the chuck to that. Do you have much lathe experience? if so, since you already have a chuck with the reverse jaws, you could make one yourself. It is not a difficult job, but might be beyond the skills range of a beginner. Otherwise you will probably have to get one made, so will need to measure whether you have the 1 3/8 or 1/1/2 inch diameter headstock spindle thread. Whoever makes the backplate will probably need to have the chuck too so he can fit the backplate to it.
The chucks shown in the Hare and Forbes link are of Chinese manufacture and are at the bottom end of the price scale.. Generally speaking the cheaper Chinese chucks (like these) are variable in quality, some may be quite OK, others of the same make and model may have faults which make them almost useless. I am not pointing the finger at H & F, this applies to all chucks in this price range as far as I know. Better chucks manufactured in Europe are available but are much more expensive. I have two cheap Chinese chucks. The quality of the 4 jaw 160mm one is not wonderful but is acceptable, the 100 mm 3 jaw is very marginal, and another 4 jaw of unknown origin (but very cheap from a closing down sale) was virtually useless because of manufacturing faults, so the cheapies are a bit of a lottery.
Frank.
29th Mar 2016, 08:21 PM #5Novice
- Mar 2016
- Robertson NSW OZ
- 11
Looks to be a decent English Chuck.
Not sure if I can buy a set for this in Oz or if I need to buy direct from the UK mob ?
29th Mar 2016, 08:23 PM #6Novice
- Mar 2016
- Robertson NSW OZ
- 11
Whats the secret to removing these chucks ?
29th Mar 2016, 08:28 PM #7Novice
- Mar 2016
- Robertson NSW OZ
- 11
Well I did a 4 year apprenticship on the tools (through all the workshops including toolroom and machine shops) on my way to becoming a Mech Engineer, many moons ago, so capable, but rusty...
It came with a 4 Jaw on a post so looks like you secure the 4 jaw in the 3 Jaw.... A faceplate would be good for what I want to play with (small parts for motorbike builds)... 1st preference is to get a set of jaws to fit the decent English 3 Jaw it came with.... I guess..
29th Mar 2016, 10:08 PM #8Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
oggy, as mentioned in your other post, Mal may be able to help you out. He has a good range of Hercus parts and chucks etc
Australian Metalworking Hobbyist
Ken
29th Mar 2016, 11:10 PM #9Most Valued Member
- 4,890
The chuck will screw off the spindle, it is a r/h thread.
You may/ will need to lock the spindle to remove the chuck, normally this is done by putting the spindle in back gear and giving the chuck a hit on the jaws or the chuck key a hit with a bit of timber or similar, you will quickly tell if it won't release and some other mechanical method will be required.
Worst case you may end up breaking some gear teeth, not a problem as spares or repairs are readily available.
If you go down the jaw route you may find it cheaper to buy either a new chuck,2nd hand with both sets of jaws or a 2nd hand chuck with xternal jaws and swap them over.
What did you mean with the 4 jaw on a pole.
30th Mar 2016, 05:20 AM #10Novice
- Mar 2016
- Robertson NSW OZ
- 11
Sorry. I was rushing a bit last night. The 4 jaw is bolted onto a flanged shaft so you clamp the shaft into the 3 jaw.
30th Mar 2016, 06:48 AM #11Philomath in training
I bought a genuine set of jaws for a Burnard chuck many years ago. Let's just say that it would have been cheaper to buy a new Chinese chuck complete. That brand is owned by 600 Machinery now.
30th Mar 2016, 09:22 AM #12Most Valued Member
- 4,890
That chuck that you show is not suitable in my opinion for metal work, it would probably be okay for wood work.
I would suggest that you also get yourself either a new or used 4 jaw metal work chuck.
If you get your self either of the chucks new you will probably need to use a back plate to mount them, if you can buy used you maybe able to get them with the 1 1/2" x 8 TPI thread integrated into the body, the latter would be preferred as the overall size of the chuck will be smaller.
30th Mar 2016, 09:32 AM #13Golden Member
- Cairns, Q
- 666
That 4 jaw chuck looks to be a fairly light duty version. I remember seeing similar ones advertised for woodworking a few years ago. What diameter is the mounting shaft, and does it have a reasonably sized through hole? If not the length of workpiece held in the chuck is limited to the depth of the chuck. The inability to feed a long workpiece through the hollow headstock spindle will be seriously inconvenient for probably the majority of jobs a general purpose lathe is used for. I suspect it won't be long before you might be looking for a conventional 4 jaw too.
Frank.
Edit: Pipeclay posted while I was typing the above
30th Mar 2016, 12:34 PM #14Banned
- Aug 2015
- QLD
- 735
Perhaps wait until you get yer-self a shaper and a pentograph. Then you can make all the chuck jaws ya want: https://m.youtube.com/watch?v=MYI1slVGziU
Wanted: 1 3/4" BSP Tap
By vincentvega in forum METALWORK GENERALReplies: 9Last Post: 29th Jul 2011, 09:39 AM -
Wanted jaws for Burnerd 4" 3 jaw chuck.
By Com_VC in forum THE HERCUS AREAReplies: 21Last Post: 31st Mar 2011, 11:51 AM -
Cheap 3" or 4" 3 Jaw Chuck
By BenM78 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 26th Oct 2010, 08:53 PM -
Wanted four jaw chuck?
By wildwesty in forum THE HERCUS AREAReplies: 5Last Post: 28th May 2009, 10:50 PM -
Wanted early hercus 9" headstock
By bitza500 in forum THE HERCUS AREAReplies: 0Last Post: 25th Dec 2008, 12:31 AM
