Results 1 to 15 of 20
Thread: Hercus No3 T&CG base dimensions
24th Aug 2015, 10:39 AM #1Novice
- Nov 2012
- 16
I recently acquired a Hercus No3 Tool & Cutter Grinder (older model with plain slides. table with 1/2" t slot without v-way.), mechanically in good shape.
It was removed from a solid timber bench (the iron pedestal base has gone AWOL some years back), and so I'm looking to (preferably) replicate the missing base.
A couple of options present.....
1) concrete and rebar
2) laminated stacked timber or MDF around a 6" steel pipe core with plate steel flange top and bottom (allowing ballast inside the pipe), painted as faux iron.
3) locate a spare pedestal (seems unlikely)
4) build a cabinet type base (including some storage), mobility would be a plus...
Knowing how heavy the top section is, I know the base is going to need to be pretty heavy with appropriate footprint to prevent tip over.
So I'm really looking for original dimensions and suggestions from the alternatives above (or any other great ideas)
Working from the bottom up.....
Base plate width = 22"
Overall height =
Base plate mounting holes = 4 x 1/2" @ 16" ctrs
Base plate thickness =
Width of square pedestal at base plate =
Radius pedestal to base plate =
Width of square pedestal at top =
Radius to edges of square pedestal =
Diameter of upper cylindrical section =
Height of upper cylindrical section =
Total height of base =
Mounting flange on grinder column = 7"ODx3"ID with 4x1/2" holes on 6" PCD
Hope you can help fill in the blanks.
Thanks and regards
John
24th Aug 2015, 10:35 PM #2Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 275
25th Aug 2015, 08:59 AM #3Novice
- Nov 2012
- 16
Hi AJ
Thanks for your reply and offer of measurements - greatly appreciated. I do not have any accessories either and will also be looking to fabricate - probably a pair of tailstocks, and a universal work head. Happy to collaborate.
John
25th Aug 2015, 08:48 PM #4Senior Member
- Feb 2012
- Willunga
- 114
Alan and John
Good luck with your machines. I have a very early number 1, despite the numbering the later model... There is a discussion of the workhead that I think fits your machines and pictures of one disassembled here (from post 35)
http://www.woodworkforums.com/showth...t=hercus+brick
I am happy to measure this up if it is useful.
Ian
26th Aug 2015, 12:36 AM #5australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
3 t&c grinder
I have a partially restored one here you can come and measure up if you would like. I am in western Sydney.
Mal
26th Aug 2015, 09:17 AM #6Novice
- Nov 2012
- 16
26th Aug 2015, 09:19 AM #7Novice
- Nov 2012
- 16
26th Aug 2015, 08:43 PM #8Senior Member
- Feb 2012
- Willunga
- 114
Hi John
If you like I could print a photo in half-tone, put some dimensions on that, photograph it and post that?
Ian
27th Aug 2015, 08:52 AM #9Novice
- Nov 2012
- 16
Ian - that would be fantastic !!!
Thank you.
Regards,
John
27th Aug 2015, 07:03 PM #10Senior Member
- Feb 2012
- Willunga
- 114
OK I will get this done over the next week.
Ian
28th Aug 2015, 02:46 PM #11Novice
- Nov 2012
- 16
With particular thanks to Mal aka allterrain50 for allowing me to measure his machine...
Overall height = 25"
Base plate thickness = 2.125"
Width of square pedestal at base plate =11"
Radius pedestal to base plate =3"
Width of square pedestal at top =9.75"
Radius to edges of square pedestal =1"
Diameter of upper cylindrical section = 8.5"
Height of upper cylindrical section =4"
Total height of base = 25"
Thanks you Mal, I really appreciate your assistance.
John
7th Sep 2015, 06:57 PM #12Senior Member
- Feb 2012
- Willunga
- 114
Hi John
Some dimensions for the work head, if these aren't clear PM me your address and I will post them.
I have tried to give you what I think would be useful to make it rather than trying to do a full measured drawing. Let me know if you would like more information.
The centre height is 3.567" and the centre is 0.125 behind the back edge of the main slide.
FWIW In measuring this I thought about how I would make it and I think that I would buy a collet spindle as a starting point.
http://www.ebay.com.au/itm/Cnc-Mill-...item5b170ad77d
It needs to be a very low friction assembly, I think that it needs simple roller bearings without seals.
Good luck and I look forward to hearing how you go.
Ian
9th Sep 2015, 11:13 AM #13Novice
- Nov 2012
- 16
Ian - Thank you so much for posting those drawings and dimensions.
Funnily enough, I have that exact ER25x150 collet chuck (from CTC Tools) and was figuring on using it for this purpose !!!
I really appreciate how much time it takes to put those drawings together.
I'll post progress to this thread. Thank you.
John
9th Sep 2015, 11:29 PM #14Senior Member
- Feb 2012
- Willunga
- 114
I missed one of the drawings
John
When I looked again at this I realized that I had posted two copies of one of the drawings and missed one.
Here it is.
Ian
10th Sep 2015, 08:31 AM #15Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Thank you
Jordan
D1-4 pin dimensions
By Ueee in forum METALWORK GENERALReplies: 18Last Post: 21st Jun 2014, 07:28 PM -
Hercus front oiler thread pitch and dimensions?
By neevo in forum THE HERCUS AREAReplies: 25Last Post: 21st Apr 2014, 01:42 PM -
Need some dimensions
By neksmerj in forum METALWORK GENERALReplies: 6Last Post: 16th Mar 2013, 05:40 PM
