Results 1 to 11 of 11
Thread: Just using what you have.
11th Jul 2015, 06:57 PM #1Most Valued Member
- 4,890
I have been asked to have a go at making some tee slotted cross slides to suit the 9" and 260,just curious if people think they would be worth doing if you didn't have the correct tooling for measurement.
I only have a micrometer, and engineers square, ground bar, adjustable parallels and other basic measuring tools.
I don't have metrology gear or surface plate.
My only accurate method of measuring or doing anything is experience.
Do you think there might be a chance that people would be interested in them.
15th Jul 2015, 09:09 PM #2Novice
- Mar 2012
- sydney
- 11
cross slide
I would be interested providing you are using tapered adjustment, not the stupid arrangement on the origninal with 3 grub srews and it will fit the 260
Tore
15th Jul 2015, 10:04 PM #3Golden Member
- Nov 2010
- Gippsland Victoria
- 733
Tee slotted cross slide
Pipeclay,
What ballpark price are we looking at ?
Bill the scrooge is interested in lots of things depending upon cost involved.
Bill
16th Jul 2015, 02:54 PM #4Most Valued Member
- 4,890
I am not selling these,I have been asked to have a go at making them, the drawings that I have call for the standard type gib.
16th Jul 2015, 05:21 PM #5Cba
- Aug 2007
- 68
- 1,410
There is nothing critical with making these. You will be fine without surface plate and without any need for scraping. You may have to rough out the castings all around before finishing to avoid warping - maybe do this twice. The dovetails are easy to measure with dowels and micrometer.
The hardest task is I think, applying the graduated scale for the compound angle. The originals had this stamped in one setup, obviously that is for mass production and not viable for a small batch in your shop. I would probably engrave the lines on the rotary table, and stamp the numbers maybe with a gig.... and probably spend a whole day on it to make it look nice....
The gib strip needs be straight and untwisted, else the slide will not be a joy to use. To check this you may indeed need a small surface plate. Not a super precision one, a free marble plate cutoff from a bathroom/kitchen marble supplier will perfectly do for this smallish task. They often throw marble cutoffs out to the kerb for people to take, before the tip truck comes along.
17th Jul 2015, 12:43 AM #6Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Article on machining a slotted cross slide from a casting here: http://tinyurl.com/o6sl2hv
South Bend, like Hercus.
Jordan
17th Jul 2015, 10:04 AM #7Golden Member
- Nov 2010
- 733
Sorry Pipeclay, I completely misunderstood your post.
I'd be very interested in any discussion you'd care to post regarding how you'd go about this job.
Would this picture that you posted previously in another thread be some sort of starting point ?
http://www.woodworkforums.com/attach...5&d=1429857302
Bill
17th Jul 2015, 10:38 AM #8Most Valued Member
I would love one for my 260.
17th Jul 2015, 10:40 AM #9Most Valued Member
- 4,890
Hello Bill more along the lines of this but with four slots.
The other type with the add on piece was only a thought to a cheap alternative.
17th Jul 2015, 10:49 AM #10Most Valued Member
I would be happy with a drop-in ring like this slotted cross-slide has:
http://www.lathes.co.uk/boxfordtslottedcrossslide/
17th Jul 2015, 09:51 PM #11Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Graduations,
Hi Pipeclay,
Good onya for having a go, reckon I know who your client is.
If I'm right, the problem of the graduations is already solved with a press.
http://www.woodworkforums.com/showthread.php?t=178700
Ken
