Results 1 to 5 of 5
Thread: Hercus Vertical Head.
9th May 2015, 08:44 PM #1Senior Member
- Brisbane Australia
- 122
Hi Guys.
Trying to help out a young bloke who has an O mill S/N OLM 528 , came from a school and the vertical head has never been fitted or used, still has packing grease on gear , it has a collet adapter fitted and not having a manual or exploded view am reluctant to get too heavy handed in trying to remove it , am I correct in thinking this adapter is just fitted into the Morse taper and held in place by the draw bar on the collet and should tap out of the Morse taper with draw bar and collet removed or is there some other procedure required ??
Jim.
10th May 2015, 08:06 AM #2Senior Member
- Jul 2012
- Griffith NSW
- 435
Your thinking is correct. A bit of 20mm rod down the hole and a gentle tap should see it fall out.
10th May 2015, 08:18 AM #3Diamond Member
- Sydney, NSW
- 1,249
Hi,
When I got mine it was the same. I gently knocked it out with some bar but I sprayed WD40 or some other lubricant to help release it.
Ben
10th May 2015, 11:07 AM #4Golden Member
- Nov 2005
- adelaide
- 597
this is what i use for a collet remover bit of toilet roll inner tube filled with lead and a handle attached
a bit of a tap on the head of the drawer bar and out it comes
john
12th May 2015, 08:05 AM #5Senior Member
- 122
Thanks for the reply's guys , had to make a support collar and use the press , it was ridiculously tight but all good now.
Jim.
Hercus Model O Vertical Head Clearance
By gdonald in forum THE HERCUS AREAReplies: 14Last Post: 16th Jun 2014, 08:45 AM -
Vertical Milling Head for Horizontal Mill
By seafurymike in forum METALWORK GENERALReplies: 42Last Post: 16th May 2012, 05:23 PM -
Hercus Vertical Milling Attachment
By Rodd Perrin in forum THE HERCUS AREAReplies: 9Last Post: 1st Nov 2011, 09:33 AM -
What's in a vertical head?
By neksmerj in forum METALWORK GENERALReplies: 25Last Post: 19th Apr 2011, 05:11 PM -
N.S.W. Hercus Vertical Milling Attachment Castings etc
By Swarfmaker1 in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 7th Dec 2010, 10:13 AM
