Results 1 to 12 of 12
    Mar 2015
    Maidavale
    2
    Default Hercus 9" AR Belt change
    Can anyone tell me how to get the rear shaft(Back Gear) out please so I can change the belt.
    Thank you
    Mike
    Jul 2008
    near Warragul, Victoria
    3,726
    Default shaft
    The countershaft ?
    On my Sheraton, similar to a Hercus. There are allen head grub screws holding the V belt cone pulley assembly onto the shaft , look for holes in the pulley where you can insert a allen key and loosen the screws . You may have to remove the large pulley on the end with a puller , look for the locking screws on the hub of the pulley . After the pullies are loose you can hit the shaft out , be careful not to mushroom the end of the shaft , use a soft drift
    Mar 2015
    Maidavale
    2
    The countershaft ?
    Thanks for that, I have the V pulleys out it is the eccentric one behind that I am having trouble with as I have the 2 bolts removed from underneath but it does not move.
    Do you know if there is a manual available.
    Jul 2008
    3,726
    Default pics
    Quote Originally Posted by MikeMaidavale View Post
    Best thing to do is post a few pics of the problem here . Mike
    Nov 2008
    Perth WA
    6,459
    Mike,
    You must have a "P" pattern drive on your lathe? On the upright "H" pattern, the backgear isn't in the way.
    There is a taper pin on the eccentric shaft bush at the right hand end of the backgear assembly. The small end of the pin should be rearmost when the backgear is disengaged.. Mark the position of the eccentric shaft bush because taper pins are often intentionally located off centre, then drive the pin out. Remove the bush and the backgear from the eccentric shaft. Easy.
    Bob.
    Jan 2012
    88
    Does anyone have any experience with using the link / joint type V belts? Would avoid having to get right in amongst it for a simple belt change!
    Sep 2010
    Venus Bay Vic
    6
    I've been running one of these on my Craftsman since 2008, no stretch or fraying, excellent.
    http://www.fennerdrives.com/powertwi...-Plus-A/13/4L/
    Noel
    Nov 2008
    Perth WA
    6,459
    I tried a link belt on my ARL and the belt rubbed against the rear quill gear guard. The Gates belt I use is 0.515" wide and the link belt, 0.590". Some link belts may be narrower. I bought mine from Transeals and only use it now to determine belt lengths for when I might need a belt of an unknown size. The same belt was once fitted in my little mill but stretch was an issue. That much of an issue that the spindle and countershaft had to come out to fit a new non link belt.
    Bob.
    Mar 2011
    Dural NSW
    82
    1,203
    Default Link Belt
    Bob
    You prompted me to measure a link belt (red colour) I have had in use for about 25 yrs on an abrasive belt slitting machine.
    It got a lot of use 8hrs per day & proved to be excellent, outlasting conventional vee belts.
    It measures .517" wide.
    My guess it will outlast me
    So the .517" link belt seems to be the winner !
    Bruce
    Nov 2008
    Perth WA
    6,459
    Quote Originally Posted by Abratool View Post
    Bob
    Bruce
    25 years! Not bad Bruce. Who made the belt?
    Bob.
    Mar 2011
    Dural NSW
    82
    1,203
    Default Belts
    Bob.
    Yes, good belts.
    There are 2 of them
    A 1 1/2" dia vee pulley (machined from mild steel) off the 1400 rpm motor to a 4"dia on an air clutch.
    Then a 3" dia to a 12" dia vee
    The 1 1/2" vee pulley would wear out & has been replaced a few times, (always kept a spare as this machine had to be kept running, in my busy business at the time)
    Conventional vee belts were always being replaced, until an old bloke at Blackwoods, put me onto the red Link Belts.
    They are "PowerTwist" made by Fenner Manheim 311 West Stiegel St Manheim PA 1545 USA 800-243-3374
    regards
    Bruce
    ps I have a lot of difficulty typing anything on this forum as it jumps & stop starts, misses letters etc.
    If any one or a moderator could assist, that would be appreciated.
    Took many minutes just to type this message !!!!!!!
    Nov 2005
    adelaide
    597
    power twist is the one to use the others sit a bit to proud of the pulley Vs
    shop around for price try motion industries there was a branch in most capital cities when i got mine
    john
  1. Replies: 3
    Last Post: 15th Dec 2014, 07:45 PM
  2. Flat belt 9" Hercus Lathe
    By omshree in forum THE HERCUS AREA
    Last Post: 17th May 2012, 11:56 PM
  3. Hercus 9" Change Gear Set For Sale
    By checkyoursix in forum THE HERCUS AREA
    Last Post: 7th Jan 2012, 02:04 PM
  4. 9" Hercus Craftsman Change Gears
    By Mark2 in forum THE HERCUS AREA
    Last Post: 22nd Feb 2010, 06:39 PM
  5. Replies: 10
    Last Post: 10th Jun 2007, 10:37 AM
