Results 16 to 30 of 49
Thread: New Hercus owner
14th Dec 2014, 10:14 AM #16Member: Blue and white apron brigade
- 7,182
Ratters (what a good name - sir, you are indeed a rat! ) what a fantastic collection of tooling and a nice little lathe as well!
I ended up getting my Hercus as a freeby so I was the able to spend the money I was going to spend on the lathe on a set of gears and some tooling but would still not have 1/10th of the gear you showed on the pics.
14th Dec 2014, 09:57 PM #17Most Valued Member
Hi ratters,
great find. You'll be able to do some excellent work with that gear.
It saddens me though to see old blokes parting with their gear. At least it's gone to someone who appreciates it.
I'll be in the same predicament as that old bloke in a couple of decades.
14th Dec 2014, 10:14 PM #18Senior Member
- Dec 2014
- Tasmania
- 102
OK well this afternoon I performed my first real operation on the lathe, to try and determine what kind of taper it would turn over a length of bar stock. I used a piece of aluminium bar stock and drilled a hole for the tailstock end using a center drillbit, then set the lathe speed and gearbox to the slowest possible feed speed for the power feed and let it run the whole length of the bar which ended up being a 41cm cut. It took bloody ages, I didn't keep time but I think at least 20 minutes. Well the big question I have for you guys is whether the results are any good..? 0.967" at the chuck end and 0.976" at the tailstock end. Is this kind of accuracy acceptable for a 41cm cut? Bear in mind I have a less than ideal bench at the moment which isnt totally rock solid and I am also a total novice so if that result is bad maybe I can take suggestions on how to improve it? The next thing I plan to do is work out how to mount that runout guage and see what kind of measurements I get off that.
15th Dec 2014, 09:58 AM #19Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Setting up Lathe
Ratters
The out of parallel you mentioned is not too bad for an initial set up.
I immediately thought of adjusting the tailstock screws at the base of the tailstock to bring the centres in line.
However,the error could be caused by bed twist, particularly on a flimsy mounting bench.
A suggestion, before you go any further, please get hold of the "Text Book of Turning" by Hercus previously mentioned.
It has a wealth of information on setting up & turning. Its a great "Bible" on Hercus Lathes
regards
Bruce
15th Dec 2014, 10:12 AM #20Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
Careful about the currently available Textbook of Turning. It covers the later model 260, which has a different arrangement for bed levelling from Ratter's lathe.
My 260 has screw and locknut adjustment between the bed legs and the swarf tray, whereas my 9 inch uses packing shims and normal bolts/nuts.
A downloadable earlier version of ToT covers the 9 inch models: http://www.bbssystem.com/manuals/Lathe-Tutorial.pdf
Jordan
15th Dec 2014, 03:35 PM #21
Wow... Wish Id got a 1/4 of that lot with mine!!
I started out 6 months ago knowing less than nothing! Now, thanks largely to the more learned ones on this forum and some trial & error / practice, I know feel as though I know just a tad more than nothing! Having said that I am loving the learning curve.
Jon
16th Dec 2014, 06:46 PM #22New Member
- Aug 2014
- 2
Hercus brochures
Hercus quote 1962.pdfHercus brochure.pdf
Hi Ratters,
I don't think I've ever seen so much good stuff offered with a lathe! This was a very lucky find. The others on the forum have identified most of the items but the attached Hercus brochure and quote from around 1962 have a bit more detail.
17th Dec 2014, 09:45 AM #23Mechanical Butcher
- Oct 2004
- 1,894
Maybe the bracket in the top-right of photo that includes the cross slide ("odds & sods") is part of the taper turning attachment?
The part that clamps to the bed and connects to the tie rod seems to be missing from the lathe photo.
Not to put a damper on enjoyment of this terrific lathe, but some caution might be worth mentioning.
When I got my first lathe, I wanted a Hercus but couldn't afford a new one and didn't find a good used one. So I bought a Taiwan machine.
Turned out to be lucky, because during the learning phase I did some damage to that lathe!
Namely, I left some soluble oil on it, which made a nasty looking rust patch on the bed. I also managed to strip a bronze gear in the saddle, and had a few "crashes" before I got a hang of it. Later I found a Hercus, and didn't have to subject it to such torture.
Not saying you're as clumsy as I was, just food for thought.
Jordan
17th Dec 2014, 01:46 PM #24Senior Member
- Dec 2014
- Tasmania
- 102
Thanks for posting the links to those PDF files guys! I will study the Text Book of Turning a bit and I'm sure it will fill in lots of knowledge gaps. Although I will say that my best resource at this point has definitely been YouTube, for 2 reasons actually. Firstly there are just a lot of lathe operations covered which are not brand specific, but the other thing is there are loads of South Bend videos too which actually do show operations which pertain to the Hercus so that alone has helped me out a great deal.
One thing I am interested in with the accessories that I have for my lathe is that a lot of them are painted in the same dark grey colour as the late, and I'm curious as to whether they were standard accessories that came with it or perhaps just options that the original owner purchased at the time.
I do have another general question though which I'm sure somebody will answer, I am surprised about the top speed of the lathe not being quite as fast as I had imagined? I mean its fast but I had expected it to be quicker, and so I wonder does this limit me from any kind of jobs that need to be performed at a higher speed or it really doesn't matter?
@Jordan - Fingers crossed I don't do any damage to it but thus far I have been very gentle in all respects so hopefully I dont make too many begginers mistakes!!
17th Dec 2014, 04:02 PM #25Most Valued Member
- 4,887
In regards to the accessories , I think all bar the thread chasing dial, change gears and steadies would of been extras. If asked for and ordered at the same time as the lathe they would probably of been the same colour.
Hercus had a few colour changes through there life and all extras that required paint would of all been painted the same colour at each time.
In regards to the top speed do you have the single pully or duplex pully set up.If duplex the speed range should be ok for nearly all machining tasks.
If you only have the single pully this will still be suitable for most machining task although sometimes it is a little slow for small diameter work or brass and ali etc.
You would need to change the generally machining guide lines to accommadate the lower speeds.
HSS and Carbide can be used on the lathe.
17th Dec 2014, 04:13 PM #26Senior Member
- Dec 2014
- Tasmania
- 102
I think perhaps it would be the duplex pulley setup, the pulley directly attached to the electric motor has 2 sizes.
Actually during some of my readings I see speed recommendations in RPM and SFM and this obviously requires some kind of tacho. Has anyone out there retro-fitted one to thier hercus so they can keep track of this?
17th Dec 2014, 05:47 PM #27Most Valued Member
- 4,887
No tacho required, just set the rpm or do the calcs for SFM.
17th Dec 2014, 06:24 PM #28Mechanical Butcher
- Oct 2004
- 1,894
I'm under the impression that to have higher speeds, you need 2 things on a Hercus bench lathe: A double pulley primary drive, and a roller bearing headstock.
Running higher than about 1,000 rpm with plain bearings, things could get hot and bothered.
Is there an "R" in the model number? That would indicate frictionless roller bearings.
You can buy a digital-laser tachometer for under $20 online. Just put some light-coloured tape on the chuck and aim the tacho at it.
Not really needed, but fun.
Jordan
17th Dec 2014, 06:44 PM #29Most Valued Member
- 4,887
The lathe in question is a plain bearing headstock model visible in the photo supplied.
Fast and low speed was an available option for all models whether plain or roller bearing.
The plain bearing models had a top rpm of around 1050/1100, with the rollers around 2600.
The only difference with the plain bearing models was whether they were flat belt 3 pully or 4 vee pully.
22nd Dec 2014, 07:14 PM #30Senior Member
- Dec 2014
- Tasmania
- 102
New Hercus model A owner.
By flmath in forum THE HERCUS AREAReplies: 1Last Post: 9th Aug 2012, 09:26 AM -
New Hercus Owner
By Iggsy in forum THE HERCUS AREAReplies: 9Last Post: 6th Dec 2011, 01:31 PM -
Prospective Hercus owner
By zbm in forum THE HERCUS AREAReplies: 2Last Post: 12th Oct 2010, 07:06 PM -
New Hercus owner
By jamie_c in forum THE HERCUS AREAReplies: 1Last Post: 23rd Oct 2009, 01:32 AM -
New Hercus Owner
By Mr Santa in forum THE HERCUS AREAReplies: 2Last Post: 16th Apr 2009, 11:19 PM
