Results 1 to 10 of 10
28th Jun 2014, 01:58 PM #1australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
Standard gear configuration for Hercus 9" and 260 lathes
I realise this has been dealt with on numerous occasions but I thought I'd put it up in new thread. I have been asked by new owners repeatedly for the standard gear setup for all the B and C model lathes. This is the basic set for the lowest feedrate hence the best finish. It does not include the ones required for higher feedrates or thread cutting. All models excluding the A and AM have this as the basic turning set.
This setup should enable the user to achieve a bright finish in general turning work, depending on spindle speed and tool tip geometry. The attached photo shows how this is setup.
Mal
28th Jun 2014, 04:30 PM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Good one, Mal.
Having pictures with text indicating the tooth counts is the clearest way of getting this info across.
Together with Pipeclay's photo of the 9A gearing, it's a useful reference.
Jordan
28th Jun 2014, 08:15 PM #3australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
Just to keep them in the same thread here is the imperail setup for the A models
24th Jul 2014, 07:43 PM #4australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
model B and C all gears
Complete gear set for Hercus 9 and 260 imperial models “B” and “C”16 22 20 24 27 32 32 33 36 40 42 44 46 48 52 54 56 57 60 80 80 IDLER 72-18 IDLER 63-60
IDLER 54-18 IDLER 45-18
IDLER
and for cutting metric threads using the 60-63 compound gear set, which replaces the 100-127.
while the 60-63 is not an exact replacement for the 100-127, the error generated is only 0.001" in 8" of thread bold numbers are for the metric threads only
17th Sep 2014, 08:50 PM #5australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
260atm standard gears
Another standard gearset this time for the 260ATM. In this case the 18 and 45 change position as required by your gearbox plate. This also applies to the 260AGM and DGM.
21st Oct 2014, 08:50 AM #6australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
metric threads on imperial 9 lathes 127/100 versus 60/63
Thought I should post the comparison between the two options for people wanting to cut metric threads on an imperial 9" A model Hercus lathe. I believe the error in the 60-63 compared to the 127-100, is so small as to not be worth worrying about. There is also the question of price as the 127-100 is way too expensive. See the attached word document.
22nd Oct 2014, 11:59 AM #7australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
INCH TO METRIC MODEL 9AS
I was asked if the 60-63 setup would actually bridge the gap between the leadscrew and stud gear, the best answer is the attached picture. Nice and compact compared to the 100-127 setup isn't it and no trouble closing the gear cover. If needed you can swap the 21 tooth gear for a 42 and select the next feed rate. See the attached options.
9th Sep 2015, 02:32 AM #8australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
ARM gears
This is the standard gearset for the metric Hercus 9 ARM
23rd Aug 2017, 11:49 AM #9Member
- Aug 2016
- 80
I'd like to see a similar picture for the 260A machine. Anyone able to do that?
23rd Aug 2017, 10:15 PM #10australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
Hercus Lathes
By whitem in forum THE HERCUS AREAReplies: 10Last Post: 2nd Jan 2013, 08:03 PM -
Hercus Lathes
By whitem in forum THE HERCUS AREAReplies: 19Last Post: 14th Dec 2012, 02:33 PM -
Hercus Lathes.
By bob colles in forum METALWORK GENERALReplies: 5Last Post: 29th Jul 2012, 04:35 PM -
Large Hercus lathes
By Greg Q in forum METALWORK GENERALReplies: 11Last Post: 6th Apr 2009, 09:59 PM
