Results 16 to 30 of 36
Thread: 22" Camelback Drill press
26th Apr 2014, 10:01 AM #16Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Outstanding Ewan, love the colour as well.
A tip when machining small taper pins like that.
I chuck the stock and drill and use a centre for the tailstock.
I then undercut the stock at the small end for the tool entry. This way I can machine the whole taper pin with end support.
When finished, I just cut off the excess and use a file for the deformation chamfer.
Phil
27th Apr 2014, 02:15 AM #17
Hi Bob,
All the smaller parts were just cleaned/ striped in a weak caustic bath. I have found this to be easier and more consistent than electrolysis. At 1/4 strength it is fairly safe, i still don gloves, a mask and have a bottle of vinegar handy when using it (and make sure the kids can't get to it!) but if you get splashed it is no big deal, it doesn't burn just makes you feel "slimy". The main casting was easily striped back to the primer with a paint scraper, then i just gave it a sand and a good clean with turps before painting. All the moving parts were soaked and scrubbed in diesel. I put the pulleys on the lathe and wire brushed/scotch brighted them.
The pulleys and belt is on now, i think i may need to shorten it though, we'll see. I don't really know just how tight it will need to be. The 4 main bronze bearings have a slot machined in them for 3/4 of the length that has a felt in it to regulate the oil supply. Just need to put a second coat on the rest of the parts and put it all back together. I do need to re-wire it as well as the old insulation is all crumbling off.
Thanks for the tip Phil. Any longer and the pin would have needed support for sure. Having the TTA and being able to use the feed makes a huge difference in what you can cut over hand feeding the compound though. There is no way i could have done it unsupported without the feed! Oddly enough your suggestion is exactly what i was suggesting yesterday in the thread on the main MW forum, didn't occur to me to use it for taper pins though.
27th Apr 2014, 04:13 PM #18Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Ew,
Thanks for the information on your cleaning methods, the drill rebuild looks as good as new. That fine feed and gearbox are a work of art as well,encased in a housing filled with oil they should last forever. One of the better designed drills,it is interesting looking at how this style of drill has evolved over all the years they have been around. Looking forward to your progress and seeing it drilling.
Bob
27th Apr 2014, 08:46 PM #19
Beautiful restoration job!
Thanks for letting us look over your shoulder!Cheers, Joe
15th Jun 2014, 02:29 AM #20
Well the drill is finally up and running.
I mentioned in one of Deans threads about the wooden dowels in the motor
I still have to get a few of the guards finished and then sort out some guarding for the belts.
This is a piddly 19mm hole with no pilot, i have since pushed a 1" with no worries.
I have found the feeds to be a bit on the fast side, i have not measured them yet but i have only used the slowest for any serious work. Unlike Stuarts mine seems to be pretty quiet, even going flat out. Maybe your bevel gears are somewhat worn Stu?
15th Jun 2014, 07:51 AM #21Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Ueee,
Thanks for the update, the drill looks really good you have done a nice job on the cleanup. I have seen old motors with wooden dowels in them before. We used to buy old burnt out motors and reclaim the copper for a non ferrous foundry that we owned back in 1960-1980 and our local scrap dealer dealer would have a big bonfire when the collection was big enough. Where did you source the leather belt from,I am quite a fair time away from needing one but it is nice knowing where to source parts. The curls on your drilling look pretty tight for low speed don't they?
Bob
18th Aug 2014, 01:58 PM #22New Member
- Aug 2012
- Brisbane
- 0
Weak caustic solution?
Hi Ew,
I have come come across an old Hercus drill that I plan on restoring as well. I have no experience in stripping paint off machinery, but you mentioned a weak caustic bath? What are the ingredients you used, measurements and any tips, particularly given it is so big etc. Any advice would help greatly.
Regards,
Raymond
18th Aug 2014, 07:53 PM #23
Really nice job Ew.....Now when did you say you were delivering it to my shed????
18th Aug 2014, 10:31 PM #24
Hi Raymond,
For the Hercus i put every part i wanted to strip in the caustic, except for the main casting. It is a little big.....
I use a 50l tub from bunnings, and 1/4 the recommended amount of caustic. Leave stuff for a day, then give it a scrub with a washing up brush to remove the stubborn stuff and let it go another day. There is no need to de-grease first the caustic will take care of that. As for the main casting i took to it with a paint scraper and then washed it down with turps, then sanded what was left.
The biggest think to remember with these drills is that they have a weight in the column to counterbalance the quill. Getting it back in was one of the hardest things to do i found.
18th Aug 2014, 10:35 PM #251915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
19th Aug 2014, 02:37 PM #26
caustic
with the caustic,ive used it for many years ... it works better if you can keep the solutionwarm . Ive got one of those immersable heating elements , they use them in farm dairysfor steralizing stuff .
20th Aug 2014, 08:23 AM #27
What is the caustic product/brand you guys recommend?
20th Aug 2014, 11:53 AM #28New Member
- Aug 2012
- Brisbane
- 0
20th Aug 2014, 02:28 PM #29
I'll check the length. The motor is 2hp 4 pole (1440rpm).
Dsel, i just use the Diggers brand from Bunnies, i would think that caustic soda was caustic soda, no matter the brand. But then again i guess there may be industrial strength etc.
20th Aug 2014, 05:51 PM #30
Hercus 22" drill press
By Graziano in forum THE HERCUS AREAReplies: 6Last Post: 22nd Mar 2010, 09:03 PM
