Results 1 to 4 of 4
Thread: Compound Gears
3rd Feb 2014, 10:36 AM #1Tiptoeturtle Guest
Compound Gears
I wrote previously (not here exactly, in the Marketplace area perhaps) that the bore of Hercus change gears was 5/8".
I was subsequently corrected by a more knowledgable member that the bore of Hercus change gears is 9/16".
I now realise the (boring) truth is:
Hercus plain change gears have a bore of 9/16" (and a keyway).
Hercus compound change gears have a bore of 5/8". (Or something else, a larger bore even, if you remove the joining collar, the collar has no inner keyway, the collar has a bore of 5/8”.)
Or, at least, that is the case on a 1946 model C.
To satisfy my unending thirst for new information and partially assuage my uncontrollable urge for verbosity:
Hercus made 36/18 45/18 54/18 63/64 72/18 100/127 and 120/127 compound gears.
I am wondering if they made (and looking for to purchase secondhand) 27/18 or 90/18 ?
Has anyone come across these ? Or are there any other compound configurations I have not listed ?
Donald
3rd Feb 2014, 04:55 PM #2Most Valued Member
- 4,887
Don't think you will find those compounds too easily as 2nd hand units.
You maybe able to source individual gears from a manufacturer and then mate them together to form your compounds.
You could probably make them yourself or see if someone can make them.
There is also a 63/60 compound.
3rd Feb 2014, 06:26 PM #3Golden Member
- Nov 2005
- adelaide
- 597
TO quote "To satisfy my unending thirst for new information and partially assuage my uncontrollable urge for verbosity" or what ever that means what do you intend to use those combinations for
john
4th Feb 2014, 10:07 AM #4Tiptoeturtle Guest
Thanks for adding the 63/60. I agree I do not expect to find 27/18 or 90/18 in a short time secondhand.
For the question about use:
The usual selection of compound gears do not have 1.5:1 (i.e. 27/18) or 5:1 (i.e. 90/18) teeth ratios, I would rather have these options than not have them when it comes to machining a (worm gear ?) mechanism for moving small neodymium magnets on synchronised conveyor systems (for model railways).
Making Gears
By Chris Parks in forum METALWORK GENERALReplies: 10Last Post: 4th May 2014, 01:17 PM -
Change Gears Again
By Bryan in forum METALWORK GENERALReplies: 47Last Post: 24th Jan 2011, 10:14 PM -
260 BM,CM,B&C Compound Gears
By pipeclay in forum THE HERCUS AREAReplies: 0Last Post: 11th Jan 2010, 06:58 PM -
Change Gears
By pipeclay in forum THE HERCUS AREAReplies: 0Last Post: 8th Oct 2009, 02:54 PM
Members who have read this thread: 0
There are no members to list at the moment.
