Results 1 to 4 of 4
Thread: Tailstock height adjustment
2nd Oct 2013, 11:39 PM #1Hercus 260
- Aug 2009
- WA
- 40
Hi all, I need some shims to adjust the height (0.08mm) of the tail stock on my 260. Any recommendations?
3rd Oct 2013, 08:20 AM #2
What dimensions are the shims ? maybe you could use a couple of cheap sets of Feeler Guages.
Shane
Got the square peg in the round hole, now can't get it out !!
3rd Oct 2013, 11:39 PM #3.
- 6,459
Graeme,
I've shimmed both of my nine's tailstocks. I used brass shim cut to the shape of the mating surfaces. Shim Brass Assortment 6 Sheets X 150mm X 150mm 05mm 25mm Thick Champion | eBay
Turned out to be a laborious task, most of the labour being the measurement of the difference between the headstock and tailstock centrelines. You may have already encountered this thread - http://www.woodworkforums.com/f65/ta...6/#post1523980 Ignore it if you have.
The 3 thou shim is still approximately one and a half tenths shy of your target 0.08mm. Try your micrometer on some aluminium foil.
Good luck
Bob.
3rd Oct 2013, 11:47 PM #4australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
