Results 1 to 2 of 2
21st Sep 2013, 04:15 PM #1Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Brass inserts for oil holes on Hercus 260
Recently I dismantled the cross slide screw on the Hercus 260 lathe to machine the face of the screw as outlined in the Hercus book, & reduce backlash.
This was the first time I had taken it apart in 23 years since purchasing the lathe new.
Adjustments were made & all is good now.
There was a lot of fine cast iron crud & fine metal shavings - dirt, in the assembly that had probably entered by the small oil hole.
To minimise future problems I machined up a small brass plug as per the photos, for both the cross slide & compound slide.
Its a simple job to lubricate by taking out the plugs, oiling & then replacing. The internals now stay a lot cleaner.
regards
Bruce
21st Sep 2013, 05:38 PM #2Most Valued Member
Great idea Bruce. I'll add that to my ''to-do'' list.
what rods for thin brass to brass ??
By Mathuranatha in forum WELDINGReplies: 7Last Post: 23rd Nov 2020, 08:17 PM -
[Canberra] Help Wanted! Drilling 20mm Holes In Brass Plate
By Morbius in forum METALWORK GENERALReplies: 3Last Post: 16th Aug 2013, 08:44 PM -
VICTORIA Brass Flat Bar Assorted Sizes & 1/4" SWB Threaded Rod & 260 Carbide Brass Sheet
By thumbsucker in forum METALWORK - Machinery, Equipment, MARKETReplies: 7Last Post: 18th Mar 2013, 03:36 PM
