Results 76 to 80 of 80
Thread: Hercus OLM279
23rd Jan 2014, 06:00 AM #76Diamond Member
- Sydney, NSW
- 1,249
Hi,
Seem to have fixed the slitting saw problem. I bought a Osbourne HSS cutter from Ctools approx. same size of what I had before, and increased the speed.
Took slightly bigger cuts and no problems. Job done.
Thanks Ben.
30th Apr 2014, 07:34 AM #77Diamond Member
- Sydney, NSW
- 1,249
Hi,
I've been using the mill some lately to make up my little non-firing 12 pounder cannon. I've been oiling it every time I start her up but I dubious about how much or if any oil is being delivered via the oil nipples especially to the vertical head.
What's the best way to check? I'm thinking just take the nipple off and see?
Thanks Ben.
4th May 2014, 11:06 AM #78.
- 6,459
Hello Ben,
If you use a push pump or pom pom type oiler, you can see whether the oil is being delivered by observing the length of pump tube projecting from the pump body. Less oil in the oiler, shorter the projection. When I used my No.O it would leak oil through the vertical head's lower seal. Enough that there would be a small puddle on the table the following day.
Given my experience with grease in the nipples of my mill, I'd recommend removing ALL the nipples and checking both them and the oilways for evidence of grease. Make sure you check the spindle pulley oil nipple. My mill came with a Dymo label attached to the inside of the door stating USE OIL ONLY. Some clever fellow ignored the advice and pumped grease into the pulley nipple. There are a few threads discussing galled and seized spindles.
I am interested to hear if your vertical head runs hot. Mine does, I reckon it's a seal friction issue.
Bob.
4th May 2014, 05:33 PM #79Diamond Member
- Sydney, NSW
- 1,249
Hi Bob,
I use a pom pom type oiler. There is always less oil in there when i finish. Sometimes oil sprays out of the nipple/oiler. I took the two nipples of the VH today, they are working. What I didn't do (I just realized) is check them off the machine.
I'm confident no grease was used on the machine, the seller was adamant oil was only used. Plus there was a big pool of oil in the bottom of the case. I don't trust the oil nipple in the spindle pulley, i never feel like I'm getting enough oil in there.
The VH does get hot after awhile. Though not as much lately (effects of more use?).
Ben
15th May 2014, 07:00 PM #80Diamond Member
- Sydney, NSW
- 1,249
Carbide endmill
Hi,
I finally made up a draw bar for the ER25 Collet chuck AB gave me for my mill. The collet set I ordered from a chinese seller turned up earlier this week.
I was able to try out two carbide insert endmills from work. One was a single insert cutter, didn't really have a good result with that one. The other was a double insert cutter. The end result was slightly better on flat black bar steel. But the little Hercus isn't really up to modern insert cutters. I think I'd only use them for small steel jobs that weren't worth taking to work to do. It did chew through the aluminium though.
The draw bar is a quickie I made up just so i could use the endmills.
Ben
Hercus
By 4-6-4 in forum THE HERCUS AREAReplies: 17Last Post: 27th Oct 2011, 08:49 PM -
Hercus 9" vs hercus 260 ????????
By bitza500 in forum THE HERCUS AREAReplies: 1Last Post: 26th Jun 2009, 10:50 PM -
Hercus Oil
By Mark2 in forum THE HERCUS AREAReplies: 6Last Post: 3rd Mar 2009, 11:58 AM -
Hercus parts on Ebay from Hercus
By bollie7 in forum THE HERCUS AREAReplies: 0Last Post: 8th Oct 2008, 02:59 PM
