Results 1 to 6 of 6
29th Mar 2013, 10:19 AM #1Most Valued Member
- Jun 2012
- SA
- 1,649
Width of flats on flat belt Hercus pulleys
As the heading says, I need to know the width of the flats on early model flat belt pulleys - for 9" models.
Rob
29th Mar 2013, 06:16 PM #2Most Valued Member
- 4,890
Havent got one to measure but going by the width of the VEE's on a later model you would have an overall
distance of 3" to play with,if it was a 3 step cone they would be 1" wide.
this is only the working area of the VEE's is does not take into account the Bull Gear mounting or the rear gear .
29th Mar 2013, 07:38 PM #3Most Valued Member
- Jun 2012
- SA
- 1,649
Thanks Pipeclay.
I'm interested in the intermediate pulley as a possibility for use on my Schaublin 102 resto if I have problems rebuilding the intermediate pulley that came with it.
It has serious porosity at one end and I've been building it up with cast rods and grinding it back with the TPG - what a mess - unbelievable.
I've done some dirty jobs, but this takes the cake. I also machined about 2 Kg out of the centre to lighten it to negate imbalance from the porosity.
So far so good, but I'm just checking my options.
Rob
30th Mar 2013, 03:20 PM #4Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Pipeclay's reckoning is pretty close. My Hercus 9's intermediate cone pulley has the 3 widths, from largest to small as: 1 3/32", 1 1/16", 1 1/16".
Jordan
30th Mar 2013, 07:59 PM #5Most Valued Member
- Jun 2012
- SA
- 1,649
2nd Apr 2013, 07:50 PM #6Member
- Jan 2012
- 88
Cast Iron Repairs
Rob, depending on how you go with using cast iron rods, I've had just as much luck with the MIG with the gas turned up flat out.
Flat belt 9" Hercus Lathe
By omshree in forum THE HERCUS AREAReplies: 4Last Post: 17th May 2012, 11:56 PM -
Hercus Tool and Cutter Grinder - Spindle Drive Belt and Pulleys
By Anorak Bob in forum METALWORK GENERALReplies: 16Last Post: 6th May 2012, 03:32 PM -
Flat Belt Retailers
By Rodd Perrin in forum THE HERCUS AREAReplies: 9Last Post: 18th Aug 2010, 11:40 AM
