Results 1 to 2 of 2
    Nov 2012
    rockhampton qld
    3
    Default hercus 9" c model
    Hi guysI hope you can help me my lathe is an old Qld school lathe it was a spare so it was raided for parts. I got it cheap so alls good the main shaft was seized, I took my time to unseize it I soaked it with some good antiseize & left it for about 12 mounths. it now turns freely. I dont know where to find the serial no. The lathe needs new idler gear set & has a mcpherson tools badge on it as well I would like a spare parts catelodge And also a set of idler gears the cg72-18t gear has some teeth missing regards Marcus
    Jan 2010
    119
    Welcome to the forum Marcus. There (at least three) places which are stamped with the number - the right-hand end of the bed; the tailstock (hopefully they match); and the gearbox plate - see pics. Look forward to seeing pics of your prize - well done for unfreezing. Is this the main spindle - is there any damage to the headstock spindle bearings?
    A good place to start looking for spares is Mal at Australian Metalworking Hobbyist or Mick Moyle's Engineers Supplies
    You will find a spare parts manual on this forum at http://www.woodworkforums.com/f189/p...manual-156990/
    Please let us all know how you get on . . . . Mark
  1. Hercus Model A
    By pauljgordon in forum THE HERCUS AREA
    Last Post: 10th Mar 2012, 10:10 PM
  2. hercus model A 1951 model
    By pjh4159 in forum THE HERCUS AREA
    Last Post: 21st Aug 2011, 03:15 AM
  3. Hercus Model 0
    By SurfinNev in forum THE HERCUS AREA
    Last Post: 9th Feb 2011, 04:37 PM
  4. Hercus Model O
    By dotz in forum THE HERCUS AREA
    Last Post: 9th Feb 2011, 02:01 PM
  5. Hercus 9" Model A Feed Nuts
    By wannabe in forum THE HERCUS AREA
    Last Post: 18th Nov 2010, 11:26 AM
