Results 1 to 7 of 7
Thread: Back Gear mesh adjustment
8th Oct 2012, 04:36 PM #1Most Valued Member
The back-gear on my 260 was gradually moving out of mesh today. After about 20 seconds it would get very noisy and I would have to open the lid and reengage the lever. So I adjusted the bolt shown in the photo in the mistaken belief it was the tensioner for the back-gear lever. It turns out this bolt sets the engagement of the gears.
Anyway I worked out how to adjust the tension and that problem has gone away. However the lathe is now making a heck of a racket in back-gear. I've set the bolt to give a tiny amount of slack in the gear train. I don't know whether to tighten or loosen the mesh of the gears. I don't want to experiment in case I stuff up the gears. Is there a proper way to adjust this bolt?
8th Oct 2012, 05:42 PM #2Most Valued Member
- 4,890
If its rattling tighten the gap/mesh,if its whinning/whiring release the gap/mesh.
If overly concerned set a gap of .002"/.003'.
8th Oct 2012, 07:45 PM #3Most Valued Member
OK thanks, it sounds a bit like both but probably more rattling. I'll tighten it and see if that fixes it.
BTW, how do you measure the gap? I couldn't find anything on Google.
8th Oct 2012, 07:52 PM #4Most Valued Member
- 4,890
Use a piece of paper or plasterseen.
9th Oct 2012, 06:23 AM #5Diamond Member
- Sydney, NSW
- 1,249
9th Oct 2012, 07:54 AM #6Most Valued Member
Ben,
you adjust the tension on the eccentric shaft with a 5/32" allen key. There's a hole in the top of the headstock casting on the RHS of the shaft. Deep inside that hole is the adjusting screw. It's a fine line between being tight enough to prevent the gears jumping out of mesh and too tight to move by hand.
9th Oct 2012, 02:51 PM #7Diamond Member
- Sydney, NSW
- 1,249
Thanks for that Jack, I'll have a look this arvo.
Cheers Ben
broken tooth on back gear
By morrisman in forum THE HERCUS AREAReplies: 5Last Post: 18th Jul 2011, 11:26 AM -
Gear tooth count on Back/Bull Gear.
By pipeclay in forum THE HERCUS AREAReplies: 31Last Post: 6th Jan 2010, 11:56 AM -
Boxford Lathe - Back Gear
By fluxcored in forum METALWORK GENERALReplies: 6Last Post: 6th Feb 2009, 11:09 PM -
Rebuilt back gear
By bitza500 in forum THE HERCUS AREAReplies: 0Last Post: 19th Oct 2008, 08:41 PM
