Results 1 to 7 of 7
Thread: Sheraton or Hercus C model
1st Sep 2012, 09:20 AM #1Novice
- Mar 2009
- BATEMANS BAY
- 10
Hi folks i have a Sheraton c model lathe with imperial meisurements and know nothing about it would anyone in the Batemans Bay nsw area have one or a Hercus c model that i may have a look at and maybe get some info and hints
regards wayne
1st Sep 2012, 09:48 AM #2Most Valued Member
- 4,890
If you have no luck finding someone with a similar model can your questions or concerns be answered by written word.
1st Sep 2012, 01:13 PM #3Diamond Member
- Sydney, NSW
- 1,249
Hi,
Try this link to the Hercus Text Book of Turning.
http://www.bbssystem.com/manuals/Lathe-Tutorial.pdf
You can also buy the actual book from various places if you like.
Ben
1st Sep 2012, 04:39 PM #4Novice
- Mar 2009
- BATEMANS BAY
- 10
hercus/sheraton
i hope someone can help i have changed the apron to a hercus one and the feed wheel seems to have a fair bit of slap and when auto feeding you can notice a faintstall or slip in the wheel but not in the cage i wont know if its a problem until i get some cutting tools to seeif it leaves and marks in the surface of the job regards wayne
1st Sep 2012, 04:41 PM #5Novice
- Mar 2009
- BATEMANS BAY
- 10
2nd Sep 2012, 01:25 AM #6Most Valued Member
- 4,890
You may find that the rack on the Sheraton dosent sit as low as the Hercus.
If thats the case if its a concern you may have to shim/pack the rack down to engage better with the handwheel gear.
Did you have a problem with the Sheraton Carriage.
2nd Sep 2012, 05:02 PM #7Novice
- Mar 2009
- BATEMANS BAY
- 10
re sheraton
thanks done that today shimmed down one ml and problem would seem to be solved thankyou and i dont know if there was a problem with the sheraton one it had missing parts and i had to change the apron regards wayne
c model sheraton pics
By warnie100 in forum METALWORK GENERALReplies: 4Last Post: 30th Jul 2012, 11:16 PM -
run out on Sheraton model A
By morrisman in forum THE HERCUS AREAReplies: 14Last Post: 21st May 2011, 01:04 PM -
Sheraton Model AM Spindle removal?
By Com_VC in forum THE HERCUS AREAReplies: 19Last Post: 14th Apr 2011, 06:02 PM -
Found a Sheraton Model A
By morrisman in forum THE HERCUS AREAReplies: 0Last Post: 22nd Mar 2010, 12:41 PM -
sheraton or hercus owners I need help
By matthew_g in forum THE HERCUS AREAReplies: 1Last Post: 24th Aug 2008, 10:06 PM
