Results 1 to 10 of 10
Thread: Hercus model C info
30th Jul 2012, 09:07 PM #1New Member
- Jul 2012
- greytown new zealand
- 4
Hercus model C info
I've got a Hercus model C # 3867 that doesn't have automatic saddle and x feeds but has the 1/2 nut lever. I must admit I didn't notice that when I bought the lathe. Any information about the machine would be appreciated.
30th Jul 2012, 10:10 PM #2
Welcome
Hi
Welcome to the most informative metalwork forum on the net
Somebody will date your lathe , the serial nrs are listed somewhere ?
Seems you have a 1951 lathe
http://www.woodworkforums.com/f189/h...numbers-72007/
Some pics of your lathe would be nice
I tnink you can power feed with the half nuts , only sideways ?
Mike
31st Jul 2012, 07:57 AM #3Senior Member
- Jul 2012
- Griffith NSW
- 435
You can do longitudinal feed with the half nuts, youll need a 54-18 and a 72-18 compound gears, an 80T keyed gear and something small to put on the stud gear. If youre a smart cookie, one of your first jobs with the machine could be to fit a small motor to the cross feed lead screw.
31st Jul 2012, 09:45 AM #4New Member
- Jul 2012
- 4
Thanks for helpful info and will find out somehow how to post photos
31st Jul 2012, 09:48 AM #5New Member
- Jul 2012
- 4
Thanks, lathe came with big box overflowing with gears. I suppose each gear is stamped showing the # of teeth
1st Aug 2012, 05:50 PM #6New Member
- Jul 2012
- 4
Photos I hope
1st Aug 2012, 09:54 PM #7
belts
Looking good. You can convert it to V belt drive if you wish to . Mike
2nd Sep 2012, 04:00 PM #8
Screw Cutting Gear Chart
Hello,
Your photos don't show the cover for the screw-cutting gears so in case you don't have it, I am attaching the chart usually found on the cover.
Findlay.
4th Sep 2012, 09:18 PM #9
Nice looking machine.
In short, just like Dad's South Bend that I learnt on. One of the great things about the flat belt is that it can be easily moved between ratios. It ca also be left a little loose to reduce the breakage risk. Good for both my and Dad's nerves in the early days.
Although the qick change gearbox is convenient, I've heard it argued that being able to set the ratios direcy with the gears can be more logical.
Hope all goes well for you.cheers
David
A society grows great when old men plant trees whose shade they’ll never sit in. (Greek proverb)
4th Nov 2012, 08:03 PM #10New Member
- Nov 2012
- rockhampton qld
- 3
hercus 9 model c
Hi guys I dont know where to find the serial no the lathe needs new idler gear set & has a mcpherson tools badge on it as well I would like a spare parts catelodge And also a set of idler gears the cg72-18t gear has some teeth missing regards Marcus
Info requested re my Dad's Hercus Model 260ATL lathe
By rr9999 in forum THE HERCUS AREAReplies: 2Last Post: 28th Nov 2011, 11:34 PM -
hercus model A 1951 model
By pjh4159 in forum THE HERCUS AREAReplies: 5Last Post: 21st Aug 2011, 03:15 AM -
hercus model A
By welder in forum THE HERCUS AREAReplies: 10Last Post: 28th Feb 2010, 09:30 PM -
model c info needed
By welder in forum THE HERCUS AREAReplies: 26Last Post: 12th Nov 2009, 09:27 PM -
Hercus model A, I think not!
By neksmerj in forum THE HERCUS AREAReplies: 4Last Post: 24th Sep 2009, 05:11 PM
