Results 1 to 7 of 7
    Dec 2011
    Dunsborough WA
    28
    Question Wanted - hercus toolpost set screw
    Hello,
    Wanted:
    Does anyone have 1 spare set screw for the Hercus 4 way toolpost?
    Happy to cover costs.
    Or know where I can get 1 from?
    Think it is the 3/8"square head, 5/16BSW thread version
    I managed to break 1 when trying to remove it
    Starting to restoe a 1962 Hercus model A lathe
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Do a search for Hercus parts,otherwise search for Square heade set screw,you will more than likely find that a 5/16" BSW sq hd set screw will have a 5/16" head rather than the Hercus special 3/8" head size.
    Nov 2007
    melbourne australia
    3,228
    Michael,
    If you can't source a single screw, you can buy a set here:
    hercus 9" toolpost setscrews
    The screws with the 3/8 heads are more expensive:
    http://www.australianmetalworkinghob...product_id=169
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Thats about the same answer.
    Nov 2007
    melbourne australia
    3,228
    Sorry pipeclay, I didn't realise you had exclusive rights to answer.
    Mar 2011
    Dural NSW
    82
    1,203
    Default Toolpost set screws
    Quote Originally Posted by VK6BHY View Post
    Hello,
    Wanted:
    Did you find a set screw ? If not I may be making a few.
    Please lets know.
    regards
    Bruce
    Dec 2011
    Dunsborough WA
    28
    Smile
    Thanks for all the comments.
    I have been given a set of bolts with the smaller head very much appriciated
    I will keep a look out for 1 bolt with the larger head as got the spanner that matches or I will find a suitable spanner.
    The Lathe I have got has no tooling at all, was sitting on a rubbish tip for at leat 2 years, lucky it dont rain that often here, it will clean up quite easy, have already got the motor back working like new, kicked out the wasp nests and other dirt, a good coat of paint and new bearings have worked wonders Found what I think is the reason it got put on te tip, one of the FWD REV gears had a few teath stripped, now got a new FWS REV assembly ready to fit.
    Any tips on what tools to get
  1. Vintage Hercus Wanted
    By rickw72 in forum THE HERCUS AREA
    Last Post: 25th Jan 2012, 04:35 PM
  2. wanted Hercus or myford lathe
    By rush006 in forum THE HERCUS AREA
    Last Post: 7th Nov 2009, 06:53 PM
  3. Wood Turning Toolpost for Hercus
    By Big Shed in forum THE HERCUS AREA
    Last Post: 15th Apr 2009, 10:24 PM
