Results 1 to 12 of 12
Thread: My NEW Hercus 260 Lathe
6th Jan 2012, 02:13 PM #1Novice
- Jan 2012
- 17
Just thought I would contribute a couple of photo's of my Hercus 260 lathe which I just picked up today.
Just interested to know the significance of the Model number also.
It is marked as BTM 15895.
I have seen quite a few references to ATM and CTM models but not a BTM, does anyone know what it signifies.
regards
Jeremy
6th Jan 2012, 02:47 PM #2Most Valued Member
- 4,887
The B represents a change gear model with powered longitudinal and cross feed through a friction clutch.
6th Jan 2012, 05:50 PM #3Most Valued Member
15895 was made in 1976.
6th Jan 2012, 07:22 PM #4Novice
- Jan 2012
- 17
Thankyou gentlemen, that info is a great help.
On another subject, is anyone aware of a surplus to requirements, tailstock barrel to suit a 260 tailstock, I have managed to source all of the missing components for my tailstock, except the barrel sleeve for the unit.
6th Jan 2012, 08:20 PM #5Golden Member
- Nov 2005
- adelaide
- 597
try Australian Metalworking Hobbyist or hercus in adelaide
6th Jan 2012, 08:27 PM #6Novice
- Jan 2012
- 17
Yeah I got all of the other pieces for the tailstock from AMH but there were no tailstock barrells available, I will try Hercus in Adelaide on Monday and see what they have. I am sure they could probably make one for me, but I bet the cost would be prohibitive??
7th Jan 2012, 03:06 PM #7Golden Member
- Nov 2005
- adelaide
- 597
the part number is 5H85 they should be a stock item
john
7th Jan 2012, 03:31 PM #8Novice
- Jan 2012
- 17
Thanks John
Excuse my ignorance, but are hercus still manufacturing spares for there series of lathes or would all the parts just be New Old Stock that they have left from manufacturing?
Jeremy
7th Jan 2012, 10:38 PM #9Golden Member
- Nov 2005
- adelaide
- 597
as far as i know hercus still provide spares and refurbishment of the 260 lathe but not earlier models( but some parts are interchangeable) . there are still many 260 models being used today in schools / colleges etc
suggest you ring them for further info
john
260 Metal Lathe Refurbishment - F W Hercus Pty. Ltd - Hercus Gear Cutting - AdelaideLast edited by tanii51; 7th Jan 2012 at 10:41 PM. Reason: left link out
7th Jan 2012, 11:00 PM #10Novice
- Jan 2012
- 17
Thanks John
I will ring them on Monday, thanks for your help it is greatly appreciated.
regards
Jeremy
13th Jan 2012, 08:46 AM #11.
- 6,458
Hello Jeremy,
Following our discussion the other night, I was expecting to see some garishly painted beater. The lathe doesn't look bad at all. The only thing missing now is a gearbox.
Being an ex school machine, do the tailstock and bed serial numbers match? Sadly, there was a tendency for them to be swapped about resulting sometimes in non alignment of the spindles.
BT
13th Jan 2012, 11:58 AM #12Novice
- Jan 2012
- 17
G'day Bob
Yeah it looks ok from a distance, the headstock top cover and the headstock endcover are covered in graffitti scratched into the paintwork, right down to the aluminium in some spots. I have stripped and painted the top cover and it has come up quite well, the end cover is next and so on.
Thankfully all the numbers match from the headstock, bed and tailstock so I am hoping that half the battle is won in the alignment stakes??!!
Jeremy
Hercus Lathe Manual
By aalstin in forum THE HERCUS AREAReplies: 9Last Post: 2nd Dec 2020, 12:43 AM -
Hercus 260 as a first lathe?
By dpw700 in forum METALWORK GENERALReplies: 15Last Post: 10th Nov 2012, 09:28 PM -
Register another Hercus lathe
By dguildford in forum THE HERCUS AREAReplies: 7Last Post: 24th Sep 2009, 08:00 AM -
Hercus Lathe Oil
By Pete F in forum THE HERCUS AREAReplies: 22Last Post: 23rd Sep 2008, 09:19 AM -
Hercus Lathe
By Penpal in forum METALWORK GENERALReplies: 16Last Post: 14th Feb 2007, 02:18 AM
