Results 1 to 6 of 6
29th Apr 2011, 05:18 PM #1Diamond Member
- Aug 2006
- 1,105
How does the small compound slide come apart?
Hi,
I am having trouble getting the small compound slide that the tool holder bolts to apart.
At first I thought it would come apart like the larger slide, but it seems it is slightly different.
I have removed the gib strip and the grub screw that holds the brass nut in but I still cant get the thing apart.
Any advice would be good.
29th Apr 2011, 05:24 PM #2Most Valued Member
- 4,887
From memory you will need to either find a hole in the inner collar,the one that your micrometer dial runs around.
If there is a hole in that turn that ring,its screwed into the body of the Compound.
If there is no hole grab the ring with Multies,Stillsons or vice using suitable protection and turn it to unscrew.
The Compound Screw will then slide out attached to everything.
If you like you can remove the Handle,be careful not to lose the key or pin that locates the Handle,then the Graduated collar and then unscrew the retainer ring.
29th Apr 2011, 05:42 PM #3Diamond Member
- Aug 2006
- 1,105
Thankyou, got it out. Comes out pretty easily once you know the right way to do it.
30th Apr 2011, 03:41 AM #4Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
woodruff key
im shore i dont have to mention . that the woodfuff key is very easy to loose .
i put mine a side so as to not loose it. and could not find it when needed.
i didnt have a replacement so had to make one.
1st May 2011, 01:10 AM #5.
- 6,458
I bet it's under that can of Carlton Draught.
1st May 2011, 01:21 AM #6Most Valued Member
- Oct 2010
- 1,910
thats funny. for a second i thought who told bob. about me. then i remembered the photos
Compound slide problems.
By wm460 in forum METALWORK GENERALReplies: 3Last Post: 27th Jan 2010, 08:34 AM
