Results 1 to 15 of 19
Thread: Happy Birthday to my 260
19th Jan 2011, 10:54 PM #1Hercus 260
- Aug 2009
- WA
- 40
My Hercus 260 BTMH was 25yo in October 2010, based on the date
on the inspection sheet.
So I am a little late with the present....
Every component stripped inspected and replaced with new, as required.
All paint stripped from every component and repainted (sorry, green is for lawn mowers) No, it is not original now. (much better.)
While the components were off the bed, it was sent to Hercus to be ground.
The result is in the attached photos.
Please note that you cannot judge the true colour of an item on the internet.
I foolishly ordered the paint from a colour chart online. (doh!)
It turned out for the better when I managed to obtain tints to alter it to the hue/shade I wanted. (viz; Paula's South Bend 9" on Practical Machinist)
I wish to thank the members here for the information and inspiration and also the people at Hercus.
If you are about to work on your Hercus lathe I can recommend the book; A Guide to Renovating the South Bend Lathe 9" Model A, B&C & Model 10k
It is an invaluable source of information most relating directly to the Hercus machines and includes information not available elsewhere.(Copies available online)
So here it is (and as purchased last year).....(just have to set it up now!!)
19th Jan 2011, 11:55 PM #2.
- 6,458
Outstanding job Graham.
Find an old metal baking tray to place under the bed near the chuck to protect the nicely painted tray and more importantly, to make cleaning easier. Don't use plastic because the swarf will melt into it and cut your hand when you try to clean it off.
As for "green for lawnmowers", we'll have to disagree.
Bob.
20th Jan 2011, 12:23 AM #3Hercus 260
- Aug 2009
- WA
- 40
Thanks Bob
The learning curve is about to start!
Graeme
20th Jan 2011, 05:53 PM #4Senior Member
- Sep 2008
- Queensland
- 445
i have to say i like the colour lol last time i got paint it turned out to be the very same colour i didnt want and the same colour everything else is painted lol
nice job it should go for another 25 years before needing another servicehappy turning
Patrick
20th Jan 2011, 08:17 PM #5Cba
- Aug 2007
- 68
- 1,410
Fantastic job Graeme, congratulations!!!
20th Jan 2011, 09:20 PM #6Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
Looking good.
You have a T-slot on the compound slide - unusual.
I wouldn't mind one like that for my 260. Anybody got one to spare?
Jordan
20th Jan 2011, 10:19 PM #7Golden Member
- Mar 2009
- 54
- 825
Beautiful work Graeme.
I use a hard plastic tray which makes it easier to clean with a magnet and I also keep some newspaper on the tray when not in use to catch all the oil that invariably leaks.
I usw a 2" bristle paintbrush (proper bristle not poly) to sweep everything down when I'm done, keeps all the swarf from finding it's way to where it really shouldn't be.
This is the first time I've seen the carriage stop fitted, do you know what the extra holes on the attachment are for?
Again, a top job, well done.
Greg.
21st Jan 2011, 12:16 AM #8Hercus 260
- Aug 2009
- WA
- 40
Thanks Greg,
No, can only guess about the holes, probably travelling chip guard, maybe light or coolant?
Graeme
21st Jan 2011, 12:46 AM #9.
- 6,458
Maintaining the pristine appearance.
For what it is worth, I use a Shop Vac Classic 30, with a soft rubber Nilfisk nozzle jammed onto the hose, to clean everything off my machines. Sucks swarf out of chucks, out of spindles, off leadscrews, out of the hollow feet under the lathe bed and on and on. I hold the nozzle next to the cutter when I'm machining cast iron. Works perfecty and unlike compressed air, doesn't drive swarf and grit into unwelcome places.
Sadly, the only catch is Bunnies used to sell them. Mine is a Yank model. They were replaced by Chinese made versions then deleted from the range a few years ago.
A vacuum cleaner and a roll of paper towel are hard to beat when it comes to keeping your machine clean.
Bob.
21st Jan 2011, 12:58 AM #10.
- 6,458
Accessories
Graeme,
I have a high resolution scanned copy of the 260 accessory brochure that I can wire to you if you are interested. You can see what fits in those holes.
Bob.
21st Jan 2011, 07:54 AM #11Member
- Mar 2008
- Nth Qld
- 68
What a magnificent restoration - looks brand new. Reading your post initially before scrolling down to the pics, was worried you were going to paint it Triton yellow, esp when green was under discussion ( and discarded)
regards,
Jill
21st Jan 2011, 09:30 AM #12.
- 6,458
The only improvement
Would be a gearbox. Ring Steve D and ask him whether he has a spare one gathering dust in some long forgotten corner.
21st Jan 2011, 08:57 PM #13
Excellent job well done.
21st Jan 2011, 10:33 PM #14Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Finnowa,
Mate, that is one hell of a restoration job. Obviously you are single with no kids, cause, these things take time, lots of time. No interuptions like "Graeme, can you do the dishes".
Well done, it's a credit to you. I hope this lathe takes prime position in the living room well away from swarf, dust and rust. Without a missus, you can do this.
Most of my partly restored 9" AR, is inside.
Ken
22nd Jan 2011, 12:31 AM #15.
- 6,458
partly restored !!
Come on Ken,
the Arboga off and finish your AR! You could have bowled most of the work over while you've been waiting for that VFD
BT
