Results 1 to 8 of 8
Thread: Resto of A model in SA
10th Aug 2010, 02:02 PM #1New Member
- Mar 2010
- Huntfield Heights
- 7
Hi All
Thought I'd just post a few photos of my model A that I'm fixing up. Started by perstering a guy at work to sell it to me and is ending up a labour of love now. I've cleaned up the whole thing and slowly painting and putting back together with some much appreciated technical advice from Bitza500 (thanks Derek). Have tackled quite a few repairs on all sorts of things over the years but this is my first Lathe quite enjoying it but looking forward to actually being able to use it. Have added an as found photo as well.
Motor and spindle are on, painted headstock last night hope to put that together with Dereks new felts tonight then I have to tackle the saddle or gearbox felts next.
Darren
11th Aug 2010, 01:38 PM #2Rodddd
- 48
Hi Darren,
Looking good..
If you really want to aspire to machine tool - check out Paula's restoration of her South Bend 9a.
1947 Model 9A - Practical Machinist - Largest Manufacturing Technology Forum on the Web
There is plenty of good advice in there - and the pictures are not bad either
Rodd
13th Aug 2010, 12:55 AM #3New Member
- Mar 2010
- Huntfield Heights
- 7
Thanks Rodd
She has definatly taken that restoration up a notch from mine that saddle I couldn't believe it it actually looked like a brand new one. I got my head stock back on and turning actually used it to hold the graduated wheel off the cross slide to file the burr off so even a lathe with no gearbox saddle or tailstock is usefull for something. Here is another photo of tonights effort. I stripped the saddle tonight so will take to work and clean it in the parts washer and then paint it tomorrow night.
Darren
19th Aug 2010, 12:04 AM #4Most Valued Member
Coming along very nicely Darren
22nd Aug 2010, 10:27 AM #5Golden Member
- Nov 2005
- adelaide
- 597
darren what color /paint did you use to paint the inside of the bed ( the red bit)
i m about to start that bit on mine
john
25th Aug 2010, 12:28 AM #6New Member
- Mar 2010
- Huntfield Heights
- 7
Hi its a bit of a mixture actually I picked up 3 1litre tins of solver scarlet and one 1ltr of International red and MIxed them together to paint my trailer a few years ago this was the left over. Any bright red should be fine that was good quality machinery paint but I know that Bitza500 uses a red spray tin for that bit. Just for the record the green is British paint botanical retreat. I did contemplate yellow for inside the bed but stuck to the red.
I've got the cross slide and compound slide back on now and adjusted the gibs I'm going to make up a spacer for the cross slide to take away the slack in it. Bit cold in Adelaide at the moment so going out in the shed at night is a bit harder than normal.
Thanks Darren
1st Sep 2010, 02:42 PM #7New Member
- Mar 2010
- Huntfield Heights
- 7
Update
Just a quick up date. gearbox is now in bits I've a few worn shafts but hopefully it'll be OK if you have a cheap A box let me know. Also I've started the wireing for the forward reverse single phase and the contactor (see photos) I'll put a wiring diagram in later showing the way I've done it (if it works) I'm using the non reversing contacts from the forward reverse switch to power the control cct hopefully if you switch from forward to reverse the contactor will drop out and you will have to press the start button again to get it to change direction.
1st Sep 2010, 08:16 PM #8Golden Member
- Nov 2005
- adelaide
- 597
much better way than i did it ( fwd / rv switch) and seperate on off
takes some concentration keep wife n kids n dogs away
