Results 1 to 8 of 8
Thread: 260 restoration
    Aug 2009
    WA
    40
    Default 260 restoration
    I have dismantled my BTMH 260 for a complete repaint/rebuild.
    I was about to strip the paint from the apron in a caustic bath...but,
    what happens to the oil wick for the worm bearing in such a solution?
    Also how much of that wick should show at the other end?
    Oct 2004
    Southern Highlands NSW
    1,898
    Maybe not good to drench the wick in water/caustic, if you want it to transfer oil later.
    Why not remove all wicks, and replace them with new ones later?
    Or just scrape off the old paint? Should replace wicks anyway.
    Jordan
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Wouldnt you be better off dissmantling the apron first to seperate all the parts.
    Aug 2007
    68
    1,410
    Be careful with paint stripper. It can penetrate into the porous filler that was used to patch imperfections in the castings. The stripper will then slowly leach out such affected filler, and new paint may forewer bubble and lift off any areas above it.
    You are better off using mechanical means to remove old paint.
    You better dismantle the apron before stripping paint. Otherwise you saturate the wicks with paint stripper, causing over time corrosion of all surfaces in contact with such wick.
    Aug 2009
    WA
    40
    Thanks Chris,
    I intend to remove all paint and filler and have done so.
    I would not dream of trying to strip a part that was not dissembled.
    I will post some photos when I can.
    I removed all components and sent the bed to Hercus for a regrind.
    I do not like Vista Green so a total repaint is in order.(Inside too!)
    So one component at a time to avoid loss (and confusion)
    I have read with interest opinions on colour (and seen some shockers!)
    I will stay with popular consensis and use a machinery colour.
    Nov 2006
    Heidelberg, Victoria
    79
    2,074
    Hi Finnowa,
    Any further progress on your lathe restoration, pictures etc.
    Ken
    Aug 2009
    WA
    40
    Ken,
    You must be a mind reader or in tune with things Hercus!
    I have just finished painting and about to document (take a picture !)
    the assembly.
    I sent the bed and saddle to Hercus for a regrind. They arrived back this week and have been painted.
    So watch this space or I will start a new thread and post the pictures etc
    Thanks for asking
    Graeme
    Nov 2006
    79
    2,074
    Finnowa,
    Mind reader, I wish. I could never read my ex wife's mind, that's another story......
    Pleased to hear that the restoration is back on track. We will all be interested to hear how the bed regrind went, cost, etc. Will Hercus also regrind the 9" lathe bed. They surely must be similar.
    Pics will be great.
    Ken
