Results 1 to 8 of 8
Thread: when did it change
12th Jan 2010, 11:30 AM #1Golden Member
- Nov 2005
- adelaide
- 597
when did it change
ive just noticed my lathes (1955 model c) top slide retainer screws are on the far side of the cross slide hole and some are on the near side (see pipeclays pics in his gear cutting display) when did it change.
obviously much easy to operate from the near side
12th Jan 2010, 12:25 PM #2Most Valued Member
- 4,890
Not sure mine is around 67,it does make it a lot user friendly to have the Compound Locks on the outside.
12th Jan 2010, 09:16 PM #3Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
12th Jan 2010, 09:26 PM #4Golden Member
- Nov 2005
- adelaide
- 597
a good point i hadnt thought of
12th Jan 2010, 09:31 PM #5bitza500 Guest
This is why I need your serial Number
Hi all, this is the reason I am asking for serial Numbers so as to try and date when Hercus did their little Modifications
At present I have found all roller bearing headstock lathes had the compound bolts at the front of the crosslide ,but this does not mean they did not start earlier
Over the 71 years since 1939 Hercus did quite a few changes but until I can get as many owners to Register I will start compiling a list and approx date of the modifications that hercus did on the 9"
I am hoping to start compiling when I have at least 200 lathes on the register as this way I can then email people using THEIR date to find out what has changed during the years and then use the Serial Number to get a even more accurate date
So anybody not on the Register please email me
all the best Derek aka bitza500
[email protected]
12th Jan 2010, 09:43 PM #6Most Valued Member
- 4,890
12th Jan 2010, 10:33 PM #7bitza500 Guest
Compound lock bolts
Hi all in one of the many stories i have read Fred Hercus called the crosslide with the bolts at the back as the backward crosslide ??? but it took 40+ years before they changed the bolts to the front
As for why if the bolts are at the front you have less chance of slipping with your spanner and getting cut by a cutting tool
As I have both setups I can only see the problem undong the bolt closest to the chuck as it is near the cutting tool and could be a knuckle scraper
Having the front mounted bolts if the compound is turned it makes it hard to lock up one of the bolts
But once again another Modification that appears but in what year did they change ??
13th Jan 2010, 12:35 AM #8Member
- 52
