Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    jatt's Avatar
    jatt is offline Always within 10 paces from nearest stubby holder
    Bendigo
    51
    760
    Default Build me a dog trailer
    Yeah, cant complain about the lack of variety in the workshop. This week the orders were issued to make a 4 berth trailer. Never made one of those before. "Make it from 40 mm RHS", the boss barked.
    Kinda just making it up as I go along. Figured a basic box trailer subframe with recessed guards should do the trick.
    Using 40 mm RHS for the basic frame as well, as per request. Making up individual doorways to access each berth.
    Using 5 leaf slipper springs, GM stubs.
    So here is my progress so far.
    Frisky wife, happy life. ​Then I woke up. Oh well it was fun while it lasted.
    From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
    jatt's Avatar
    Bendigo
    51
    760
    Yeah it would help if my fotos came up
    Dec 2004
    Northen Rivers NSW
    57
    131
    looks good....have fun
    Yonnee's Avatar
    May 2007
    Tooradin, Vic.
    52
    1,318
    Holy Sheet!!
    40mm Square!! The chassis I understand, but the skeletal frame?
    So, the customer's got 4 St. Bernards.
    jatt's Avatar
    Bendigo
    51
    760
    Holy Sheet!!
    I know, I know. I argued the same point. At the end of the day I just build it the way I'm told to. The boss pays the bills (and my wage), what more can I say.
    Sep 2008
    Gold Coast
    4
    Hi
    Really interested in this build. Want to start building one soon as second hand dog trailers are a bit thin on the ground.
    Have you got some more photos?
    I wont be using 40mm for body frame as want it as light as possible.
    What will you clad it in? alloy/foam? fiberglass?
    Wayne
    Jan 2006
    Blue Mountains NSW Australia
    408
    I guess if the boss has a full pack of 50 shs that he got cheap, then that's what you make everything out of till the pack is gone.
    Aug 2009
    End of the Pitch
    5
    If you're just transporting the dogs, then you could just use Caravan cladding. Readily available.
    Yonnee's Avatar
    May 2007
    Tooradin, Vic.
    52
    1,318
    Quote Originally Posted by WicketKeeper View Post
    But if you notice, Wayne's from the QLD, so may want to consider some form of insulated panel for the heat, more than keeping them warm.
    But having said that, most of the dog floats I've seen run roof spinners and louvres in the doors, keeping them well ventilated.
    I would suggest the chassis in 40mm sq, and the rest of the frame in 25mm sq.
    Sep 2008
    Gold Coast
    4
    Hi all
    has to be insulated!!
    with the humidity and temp its got to be. It will also have vents and spinners.
    Chassis and frame sizes was what i was looking at.
    I was looking at fibreglass composite panels, already insulated, finished fibreglass exterior,
    has anyone built with panels like these?
    I havent priced but it may be a bit expensive for a one off.
    Wayne
    Jan 2006
    408
    What about cool room insulated alum panels. They are available in 2" or 4" thicknesses.
    Sep 2008
    Gold Coast
    4
    Good idea!
    I had only seen 4" ones which are too thick.
    The 2" might do the job
    Wayne
    jatt's Avatar
    Bendigo
    51
    760
    It honestly hasnt progressed much further than what u can see on the fotos.
    Have cladded one side and roof in ally caravan stuff. One sheet simply locks into another. Ran sheets along the side and will cut sections for doors in due course.
    Mentioned insulation to the boss, so far no definite replys on what he wants in that dept.
    That 2 inch cool room panelling that was suggested definetely has merit.
    But yeah when I make more progress will post more pics.
    jatt's Avatar
    Bendigo
    51
    760
    Default Finally I can work on it again
    Yep over the Xmas/new year hols I found some workshop time to do some more. Got the cladding on and sealed off around between the inside of the guards and the formply floor. Cut out cladding around the doors.
    Still lots more to do. Hopefully it wont take me several months to get time to finish the project off. The yard is once again full of vans/campers etc... so I wont hold my breath.
  15. #15
    Sep 2011
    Columbus,GA USA
    1
    What happen to the trailer? I'm starting a trailer project myself and I am going into it blind with a shape eye for light so please finish the trailer
  1. Trailer build II... the long haul.
    By Yonnee in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 7th Nov 2011, 11:32 PM
  2. Trailer Build
    By dazzler in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 8th Nov 2009, 09:03 AM
  3. Think I might build a trailer.
    By timbo123 in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 1st Oct 2008, 11:03 PM
  4. New boat trailer build
    By Stufart in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 23rd Aug 2008, 08:52 PM
  5. Well, it is a trailer
    By specialist in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 2nd Aug 2008, 10:02 AM
