Results 61 to 68 of 68
24th Aug 2021, 11:41 AM #61Senior Member
- Apr 2018
- 168
Looking good.
24th Aug 2021, 05:32 PM #62Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,836
The sprocket i chose was a Yamaha XS400 1981 the specs said the spline width was 6mm and my shafts spline was 5mm so i thought it was going to be loose but when i test fit the sprocket yesterday it fit perfect a very suitable tight fit very happy with it
When i marked out the motor and planetary gear box mounting plates i had used a texta and scribed a line with old vernier calipers so i drilled the two main shaft holes but the wd40 cooling the hole saw had rubbed off my texta marks so i need to measure everything again drill the small mounting holes than cut the piece in half and start welding20210821_124849.jpg
25th Aug 2021, 06:30 PM #63Most Valued Member
- Aug 2009
- 1,836
This is one side of the trailer mover partly done it may or may not be the right side up i will decide when i get the wheels i may try source a couple steel wheels off aold mini moke
That steel is 10mm thick and the axle is 39mm diameter so super duty those are massive flange bearings those are temp bolts all i had m12 the flange bearing takes 16mm bolts
I'm not decided weather to use my plates on the single 16mm steel it needs to be cut in half and welded onto the top cap of the mover but i may use 2 flange bearings instead for the front motor axle just means the whole movers chassis will be around 120mm wide
Drilling was so exciting... 1 hour drilling a 45mm axle hole thru 10mm steel, 35-40 brain fulled moments trying to drill 4 18mm hole saw holes than i whipped out the 12mm sharpened it and drilled those 4 holes in 5mins...
29th Aug 2021, 04:53 PM #64Most Valued Member
- Aug 2009
- 1,836
Got a bit more work done
30th Aug 2021, 12:10 PM #65Most Valued Member
- Aug 2009
- 1,836
Just welded my sprocket mount to the shaft, 39mm trailer axle to 10mm flat bar, i think i can stick weld now )
30th Aug 2021, 03:39 PM #66Most Valued Member
- Aug 2009
- 1,836
A bit more progress the trailer mover is being built upside down as pictured, i need to shortern the long side pieces as i need access for the motor and planetary gearbox to fit in there
13th Sep 2021, 06:10 PM #67Most Valued Member
- Aug 2009
- 1,836
Wheels are sitting in place waiting for hub material to be delivered, the trailer mover is upside down in the pic
19th May 2022, 02:10 AM #68Most Valued Member
- Aug 2009
- 1,836
Hey guys i forgot about this thread here is the finished heavy duty trailer mover its pushing a 2000kg 19 foot centre console boat up about 4 degree driveway on lose dirt
https://youtu.be/3Hn5CJLn4Uk
Steel Single cab ute tray to trailer project
By MasterSpoon in forum TRAILERS & OTHER FABRICATED STUFFReplies: 4Last Post: 12th Sep 2020, 05:43 PM -
Enclosed trailer build - bought an unfinished project
By bishboy in forum TRAILERS & OTHER FABRICATED STUFFReplies: 2Last Post: 29th Aug 2017, 11:24 PM -
trailer mover
By franko in forum TRAILERS & OTHER FABRICATED STUFFReplies: 14Last Post: 29th Sep 2009, 01:58 AM -
Trailer Repair Project
By neilb in forum METALWORK GENERALReplies: 18Last Post: 6th Oct 2007, 09:33 PM
