Results 1 to 7 of 7
Thread: Tailgate fastening
24th Jul 2021, 07:51 PM #1Intermediate Member
- Jul 2021
- Central NSW
- 25
Tailgate fastening
Hi folks what is the best form of tailgate fasteners - looking at antiluce (drop bolt style), over centre latches (seem to be popular), basic lever style on cheaper trailers, and ute type side board fasteners?
25th Jul 2021, 01:09 AM #2Most Valued Member
I prefer the one where you have 2 pieces of 15NB pipe about 50mm long and a piece 12 mm bar with a right angle bend on top. You can use a short section of light chain welded to the pin and to the trailer, to make sure you or whoever borrows the trailer don't loose the pins.
The anti lose (drop lock) can get tight, to the point that a hammer is required, the over centre catches can get damage as can the ute sided ones, plus these can get expensive, whereas the pipe and pin can be had for under $5 for the whole trailer. With the lever style of catch, the rivet holding the lever can and does fall out, if not welded properly, have a few here that we've had to replace.
There are a host of different catches that can be used but I prefer the KISS ones, (Keep It Simple S....) and the cheap ones. Try to avoid using the Bolt and Nut type, as the threads get damaged and can be a pain to repair if you're away from home. DAMHIKT
I used to manage a trailer hire place that had this type of catch on ALL the trailers, bolts were replaced at least one a month, and the nut part every couple of months, if it came back at all!
Not to many people care about the trailer, whether it's theirs or not, they still have that little accident where it got backed into something that wasn't there when I looked.
I've seen some trailers whereby IF they were checked for Rego, they'd FAIL.
HTH
25th Jul 2021, 06:50 AM #3Intermediate Member
- Jul 2021
- Central NSW
- 25
Had not thought of either of those - had a crate with the pin style you described, but the pin can pop out on dirt roads (so the back up is old dog collar or electrical wire twitched on… - yes I really should fix properly).
Also with the pin style probably would need to review tailgate design so can weld the pipe on.ie say 25mm angle meets flush with back of trailer - Though this would be better to seal up back of trailer.
Though thinking the antiluce ones maybe a little neater. The heavier over centre ones are exy. The back of the trailer needs to be bombproof.
25th Jul 2021, 11:54 AM #4Member
- Oct 2004
- Melbourne, Australia.
- 52
I've had the centre latches on a trailer, brilliant until I let my brother have it for some gardening work. One or two nudges into whatever he hit and the latches from then on were a pain to use. Also one latch being replaced after getting some wet soil covering the rear of the trailer for a few weeks, I could have killed him as rust rooted the threads. I suggest if you go this route, better quality units (sometimes that means bigger) seem to work easier as they can be a bit iffy to operate if they are small.
https://www.bctrailers.com.au/608-la...ntre-latch.jpg
I replaced all four of them with antiluce units and until the trailer died, they worked very well.
https://gttowing.co.uk/images_CMS/pr...916_medium.jpg
Bought a tray back ute with steel tread plate floor and 300mm steel drop sides in 2009, insisted on antiluce units, never had an issue. That said, they do at times lock up and either a tap with something like a boot, rock or stick; does the trick. They've been through the wars with a couple of marks, nicks and in the case of one of them, slightly bent, but they just do the job. They are slightly noisy as the drop sides and/or tailgate rattle a bit, but once they've locked down from vibrations, they become mostly as silent as possible.
Mick.
25th Jul 2021, 03:36 PM #5Intermediate Member
- Jul 2021
- Central NSW
- 25
I reckon a trailer might be the third thing you should never lend.
25th Jul 2021, 11:49 PM #6Most Valued Member
26th Jul 2021, 10:30 AM #7Most Valued Member
- 2,673
I’m also a fan of the anti loose type.
2 things I’ve found in regards to them sticking - make sure you use the rubber washers on them as they provide a small amount of give and makes it easy to give the tailgate a bit of a bump with your hand to release the toggle.
Secondly - after a few years they do tend to stick more often and get harder to release. I think the pin wears into the toggle a bit.
You could probably stuff around with a file and sort it out - but I figure if they are worn it’s time to just replace them.
Tailgate
By morrisman in forum AUTO RESTORATIONReplies: 1Last Post: 8th Oct 2016, 09:42 PM -
Safely Weld a Car Tailgate?
By abrogard in forum WELDINGReplies: 38Last Post: 16th May 2011, 05:52 PM -
Fastening cables to a small eye screw
By smittydd in forum METALWORK GENERALReplies: 5Last Post: 11th Apr 2010, 10:02 PM
