Results 1 to 9 of 9
Thread: 8 x 6 trailer design
17th Jul 2021, 09:59 AM #1Intermediate Member
- Jul 2021
- Central NSW
- 25
Long time forum guest here
Trying to design an 8x6 box trailer to build myself with idea of ditching my ute so I can use the trailer on a Pajero - usually for crushed granite, gravel for concreting, rubbish, wood, etc.
was thinking build it to suit 1400 kg atm with single axle mechanical brakes - made from 75x50 rhs. With 2 mm floor and 1.6mm fabricated sides using 25x25mm angle as the framing. Would would like a h frame set up for lengths of timber and steel of course.
Though is it possible to build single axle 2000kg atm trailer? All I can find is tandems in this configuration. If able to do this what axle configuration and a frame size would I go for.
Also have available a set,of mk triton springs and an old 8x6 alloy tray - not a fan of these as end up too high when lifting heave items in and out. I am all ears thanks guys
17th Jul 2021, 10:49 AM #2Golden Member
- Apr 2019
- 596
There are places that seek pre- made trailer plans on eBay. No idea if they are any good. Might pay you to check the regulations in NSW regarding registering home made trailers - they might require an engineers sign off.
Personally if you want 1800kg then I would only be happy with a tandem axle for the additional safety.
17th Jul 2021, 10:58 AM #3
You want to start with reading VSB1, it will give you the specifications that need to be met.
https://www.infrastructure.gov.au/ve...sb1/index.aspx
17th Jul 2021, 12:23 PM #4Intermediate Member
- Jul 2021
- Central NSW
- 25
23rd Jul 2021, 03:20 PM #5Novice
- Sep 2014
- SA
- 11
2T ATM is achievable with a 50mm square axle and appropriately rated leaf springs
You will need to plate the trailer under 2T to avoid the requirement for breakaway brakes. That is why a lot of trailers available have an ATM of 1990kg.
Checkout somewhere like Huntsman products for kits including axle, brakes/hubs & springs.
https://www.huntsmanproducts.com.au/...to-eye-springs
23rd Jul 2021, 07:52 PM #6Intermediate Member
- Jul 2021
- Central NSW
- 25
Thanks SW have located that site with plenty of interesting items. But build costs estimate adding up - so far have it circa $2200. The online trailer plans site don’t seem to advertise 8 x 6 plans. On further reading of the Rms site if tare comes in under 250kgs then cheaper rego available - but I don’t think that is possible as weight estimate is closer to 205kg plus suspension kit, wheels and hitch. This would be I guess the holy grail and if possible they would already available
29th Jul 2021, 11:42 PM #7Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
If you are referencing VSB1 be aware that R6 was released into the wild in Feb this year, the link posted above is to R5
30th Jul 2021, 09:11 AM #8
Thanks for the pickup
https://www.infrastructure.gov.au/ve...6-20210222.pdf
5th Aug 2021, 05:10 PM #9New Member
- Aug 2012
- 3
Having a read of R6 of the VSB, the drawbar testing would look to be the nail in the coffin for the home made trailer, unless using plans that had some sort of type approval. I imagine that getting a slot at a testing facility will not be coming cheap for someone who wants to make a one-off trailer. There's no allowance for using standard designs.
Similarly, the chain attachment appears to require testing as well.
The placard requirements have also been upped - you now need a placard that dictates the type, size and ratings of the tyres.
None of the above is insurmountable, but it's definitely not as easy as it used to be.
Engineering design question for tandem trailer
By surfin in forum TRAILERS & OTHER FABRICATED STUFFReplies: 23Last Post: 2nd Sep 2015, 09:45 PM -
Enclosed Trailer design
By Avitus in forum TRAILERS & OTHER FABRICATED STUFFReplies: 39Last Post: 1st Oct 2012, 06:19 PM -
Tilt trailer drawbar latch - wot is best design
By jex in forum TRAILERS & OTHER FABRICATED STUFFReplies: 4Last Post: 2nd Sep 2012, 10:44 PM -
trailer design help
By welder in forum TRAILERS & OTHER FABRICATED STUFFReplies: 29Last Post: 13th May 2010, 10:23 PM -
Finding Engineering Design Software For Automatic Machine Design
By davidWilliams in forum METALWORK GENERALReplies: 2Last Post: 11th Jan 2010, 10:41 PM
