Results 1 to 2 of 2
Thread: Widening a Boat Trailer
12th Mar 2021, 09:44 PM #1New Member
- Mar 2021
- 4
I’m looking at putting a longer axle on an ‘A Frame’ catamaran trailer to allow it to carry the folding trimaran shown in the first picture below. Existing trailer is second photo. The distance between the outside of the trailer guards is only 1670mm which seems somewhat narrow for the raised floats. The total weight of the boat is approx. 300kg, including floats of approx. 60kg each.
The option I’m looking at is to use a ‘bolt on’ rectangular frame as shown in the third picture below which would be bolted with U-Bolts onto the existing rectangular frame where the springs are currently attached. The springs would then be relocated to the new frame. Bolting rather than welding would allow the new frame to be removed if the trailer is required for another boat which would not be very often, but also to avoid potentially damaging the existing trailer frame by welding.
I’m thinking that the distance between the outside of the guards could be increased by say 500mm to 2,170mm with the new frame being around 1700mm x 900mm made from 50x50x3 RHS. This would reduce the overhang of the floats to only 165mm per side.
My question is whether there are any structural issues with this approach i.e. using U Bolts rather than welding or bolting through the two frames, dimensions of new frame etc. and if members have any suggested improvements or recommendations e.g. should U-Bolts be vertical or horizontal.
Any feedback would be greatly appreciated.
Blair
13th Mar 2021, 04:42 PM #2Golden Member
- Jun 2005
- Helensburgh
- 618
I would check the legality of modifying it with the relevant authorities but my gut feeling says they won't like the idea without engineering approval.
CHRIS
By Blair62 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 14th Mar 2021, 07:29 AM -
boat trailer
By brendon17 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 8Last Post: 7th Sep 2013, 11:56 PM -
Widening a trailer axle.
By Vernonv in forum TRAILERS & OTHER FABRICATED STUFFReplies: 13Last Post: 25th May 2011, 07:42 PM -
boat trailer
By spencer411 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 1Last Post: 6th Dec 2009, 11:25 AM -
boat trailer
By chippyk in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 14th Sep 2008, 03:10 PM
