Results 1 to 5 of 5
    Apr 2008
    Southern Riverina
    24
    Default Receiver hitch steel dimensions
    Bit surprised I wasn't able to find an easy answer to this on the googles.
    Is there a right choice of RHS for making hitch receivers? Obviously I could just go and find the best fit on the rack, but I wondered if there's a specific (eg US) size/profile/grade that they use.
    I have a couple of spare tongues and a winch box knocking around, that all appear to use 50mm square hollow section. I want to make up a couple of receivers (tractor, trailer etc) for general convenience moving stuff around the farm.
    Sep 2010
    Lebrina
    1,915
    Most people use 50x50x4 RHS for the internal piece and that fits into 65X65X6 RHS beautifully. For farm use anything 4-6mm wall will be fine, with 6mm being more resistant to the hole slogging out under heavy loading.
    May 2011
    Murray Bridge S Aust.
    5,959
    If you have a tow bar manufacturer near by, they may have the seamless stuff, otherwise it's file and die grinder type of work to remove the seam.
    Sep 2010
    Lebrina
    1,915
    Shouldn't be too big an issue as they don't generally fit that tightly, 65 less 2 times 6 is 53mm which leaves plenty of clearance for a seam.
    Apr 2008
    Southern Riverina
    24
    Thanks guys, sounds straightforward enough. I'll grab some next time I'm in town
  1. Hydrostatic testing a compressor receiver
    By simonl in forum METALWORK GENERAL
    Last Post: 20th May 2020, 08:16 AM
  2. Air Compressor receiver tank.
    By Theberylbloke in forum METALWORK GENERAL
    Last Post: 9th Jan 2016, 10:12 PM
  3. AL-KO Offroad Hitch - Opinions?
    By atregent in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 28th Feb 2012, 03:12 PM
  4. Air receiver explodes
    By steran50 in forum METALWORK GENERAL
    Last Post: 14th Jun 2011, 11:12 PM
  5. Finally got around to my draw bar and hitch modification.
    By Fossil in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 24th Nov 2010, 11:00 PM
