Page 9 of 10 FirstFirst ... 45678910 LastLast
Results 121 to 135 of 146
  1. #121
    Aug 2009
    Sydney, NSW, Australia
    1,844
    That works lol i will see if hare and forbes is open today
  2. #122
    Aug 2009
    1,844
    The bunnings brazing rods work i just tested it i only had a small tooth of carbide to test it worked ok wasnt taking off magic amounts of material .2mm at a time so .4mm off the radius pretty poor but it was likely my sharpening that made it not cut properly i couldnt extend the tooth over the front of the hss
    The billet and tool stayed cold after 25mins of cutting chips were tiny but again probably my sharpening, the tooth ended up falling off after i ground the tip several times probably bad bonding from my cleaning hard to sand a small 4x2mm tip
  3. #123
    Dec 2005
    South Australia
    1,658
    I give up!
  4. #124
    Aug 2009
    1,844
    What do you give up on China? Im moving house this week i cant order anything online and i cant drive anywhere to purchase anything suggested because of the lock down
  5. #125
    34
    1,080
    If you're limited to 6mm tools, get a 6mm boring bar; they take the same style of insert, just smaller https://www.ebay.com.au/itm/S06K-SCL....c101072.m2109
    Trying to braze/solder a tip on is not going to get you anything useful.
  6. #126
    Aug 2009
    1,844
    Elan i just put it on my watch list once we move i'll order it to the new address i was looking at those over the past few days it would be handy being 125mm long i only need around 70-80mm of depth so that is perfect
  7. #127
    34
    1,080
    Held as a normal turning tool, with minimal overhang, it should be fine for OD work.
    Not sure how it will go with boring that deep, especially in steel; the chatter is going to be uncontrollable with anything but the smallest cuts.
    Might be worth signing up for an AusPost parcel locker (if there's one near you) https://auspost.com.au/receiving/alt...-parcel-locker
    EDIT: The one I linked has 0.4mm radius inserts, if you need 0.2 inserts, look for CCMT060202
  8. #128
    Aug 2009
    1,844
    We have the keys to the new house and signed the papers sat morning but im just holding off buying anything untill its 100% official and we start to move in
    So hard to find 6mm tooling in aus everything is 6mm HSS or it starts at 8mm in carbide
    That boring bar is cheap as and has plenty of tips
    I am thinking of changing the steel billet to regular mild steel in 70-75mm that way i only need to bore it out to 61.75-61.85mm instead of having to machine the outside too this high tensile stuff is really hard even on the lathes motor
    Just taking .02mm cuts the motor slows right down and has stalled but likely to the blunt tool
    Regular steel is a piece of cake to machine on this lathe
  9. #129
    Aug 2009
    1,844
    I just looked up the steel its called "bright mild steel" 1020 grade wonder why i cant machine it if its regular steel i thought it was high tensile
    https://www.edconsteel.com.au/store/...ght-mild-steel
  10. #130
    34
    1,080
    If you can't machine 1020 then I dunno what more advice I can give you.
    Plugged some numbers into my calculator and it recommends 700ish RPM for 90mm diameter with coated carbide tips, 180 RPM for plain HSS.
  11. #131
    Aug 2009
    1,844
    Bugger my belts are on A-2 500rpm i have never really understood those gears in the manual but i think i can work it out now.. that will be why im having problems im spinning at to fast a speed
    Someone previously asked about my speed but i was unsure so didnt answer i have never been able to work out that diagram as there are more than 2 pulleys combined
    Guys what is with the replies? Im not a engineer in machinery this being my first lathe i dont know all the bells and wistles you guys have had decades in learning i actually feel like not posting to ask questions but its my only line of help
  12. #132
    34
    1,080
    Yeah...that was me. Tools going blunt super quickly is usually a good sign you're running too fast.
    I think you'll find that once you start asking questions appropriate to your level of experience, you'll start getting more useful answers. I'm sure most people here are genuinely happy to help beginners, but when you ask how to climb a mountain when you're still figuring out how to walk, the ONLY appropriate response is to talk you out of it in whatever way necessary. It's genuinely for your own good.
  13. #133
    Sep 2005
    Bendigo
    60
    419
    Maybe if when people ask a question in a post where you want help you could take the time to work it out and provide an answer, if you don’t understand the question ask for more information.
    People are asking questions to help you, ignoring them and the advise provided makes them feel like they are banging their head against a brick wall.
  14. #134
    Dec 2005
    South Australia
    1,658
    Yep you nailed it, Grahame
  15. #135
    34
    1,080
    If you all aren't going to be helpful, unsubscribe from the thread and ignore it.
    I thought we were better than this.
  1. Making a lathe compound slide for the mill
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 17th Jan 2020, 02:14 PM
  2. Recipe for homemade Way Oil
    Last Post: 6th Jun 2019, 10:43 AM
  3. Making gear blanks in the lathe - workholding suggestions
    By OxxAndBert in forum METALWORK GENERAL
    Last Post: 1st Aug 2018, 12:26 AM
  4. Homemade Boring Bars
    By Oldneweng in forum METALWORK GENERAL
    Last Post: 6th Sep 2011, 08:11 PM
  5. making square stock round on a metal lathe
    Last Post: 19th Apr 2010, 09:20 PM
