Results 76 to 90 of 146
Thread: Homemade lathe in the making?
8th Apr 2020, 01:21 PM #76Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
I bought the ccmt 21 51 carbide tips the add didnt mention degrees, i plan on moving the shaft up and down with the motor assembly i havent worked that out yet but it will likely just be a threaded bar so long as the motor of choice isnt yo heavy
8th Apr 2020, 01:24 PM #77Gear expert in training
- 34
- 1,079
Yeh...you gotta get a holder for the inserts.
Make sure it's the right size to suit your toolpost if it's not adjustable. Tools only work properly if the height is correct
8th Apr 2020, 01:48 PM #78Most Valued Member
- Aug 2009
- 1,844
8th Apr 2020, 06:28 PM #79Most Valued Member
- Aug 2009
- 1,844
Ran into a bit of a problem guys i picked up a mapp gas cylinder from bunnings and some silver solder paste as i already had a roll of 4mm thick silver solder and a propane torch, i removed a old tungsten tooth from a worn circular saw blade and brazed it onto one of my HSS 6mm tools first 2 brazes were poor as i have never brazed before
3rd go worked a charm i put the tool in the.post and proceeded to cut the steel billet and the tooth had became so hot the solder had melted and released the carbide tooth
Now im going down the route of brazing i think its not a good option i dont have anyway of cooling the tool i suppose i could hang a bottle of water on a slow drip feed but my lathe is small and i have 240v near the chuck i dont think its ideal
I may have to make a screw on carbide fixture as there are next to no shops in Aus that deal with 6mm carbide tooling for some reason
8th Apr 2020, 07:23 PM #80Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,553
If you have a compressor you can feed low pressure air over the tool to cool it.
Buy a 12mm tool and cut the bottom 6mm off.
I have some 20mm Seco insert tools that I got from an estate that have had the bottom milled out, rather conveniently they are the correct size for my Hercus tool post.
8th Apr 2020, 07:28 PM #81Most Valued Member
- Aug 2009
- 1,844
Racing now thats an idea, we are moving house and just got notified of another house available so it means i have to leave behind my 15amp outlet my compressor is 3 horse power bugger
8th Apr 2020, 08:01 PM #82Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
Are you using soft solder ( lead/tin), or proper silver solder?
8th Apr 2020, 08:04 PM #83Most Valued Member
- Aug 2009
- 1,844
Hey Techno proper silver solder i bought it a few years ago in mistake for normal wire soldering
I'll grab a set of the bigger carbide tools and cut them down i didnt even think of doing that
8th Apr 2020, 08:25 PM #84Most Valued Member
- Mar 2011
- 1,553
If it’s on a roll chances are it’s probably soft solder. Silver solder is usually in rods that have a label telling you the silver content. 2% and 5% are commonly used in plumbing/refrigeration pipe works. The higher the silver content, the more expensive the cost of the rod will be.
8th Apr 2020, 08:29 PM #85Most Valued Member
- Aug 2009
- 1,844
Yeah its about 4mm thick on a roll the writting just said silver solder i'll grab the stiff rods and try that before i fork out for a 8mm kit thanks
8th Apr 2020, 08:43 PM #86Most Valued Member
- 70
- 1,513
SBA245 for brazing tips is what I would use. Expensive, but you can braze a lot of tips with one length of rod.
Nev.
9th Apr 2020, 02:12 AM #87Most Valued Member
- Aug 2009
- 1,844
Should i see if my bunnings has this SBA rod
https://www.bunnings.com.au/consolid...stick_p5060118
Or should u buy this 2 pack?
https://www.bunnings.com.au/silver-b...s-2pk_p5910514
Once i have this brazing sorted i should be on the right track this thread has been a bit messed up and gone cockeyed
I will see if admin can remove this derailed thread i'll start another one for the purpous of a fresh build along
9th Apr 2020, 06:43 AM #88Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
9th Apr 2020, 11:29 AM #89Most Valued Member
- Aug 2009
- 1,844
Thanks Nigel for the offer my tool post is 6mm so your tools are too big, my lathe is only a 5x12" mini Hobbymat MD65
my carbides should be here any time now and we are moving house so complicates things
9th Apr 2020, 11:34 AM #90Most Valued Member
- Aug 2009
- 1,844
These are the carbides i bought https://www.ebay.com.au/itm/AU-10-CC...6-80ce49c9c245 does it matter that they are gold? I have seen the carbides for cutting hard steel are grey or black
Making a lathe compound slide for the mill
By KBs PensNmore in forum METALWORK GENERALReplies: 0Last Post: 17th Jan 2020, 02:14 PM -
Recipe for homemade Way Oil
By KBs PensNmore in forum METALWORK GENERALReplies: 6Last Post: 6th Jun 2019, 10:43 AM -
Making gear blanks in the lathe - workholding suggestions
By OxxAndBert in forum METALWORK GENERALReplies: 13Last Post: 1st Aug 2018, 12:26 AM -
Homemade Boring Bars
By Oldneweng in forum METALWORK GENERALReplies: 19Last Post: 6th Sep 2011, 08:11 PM -
making square stock round on a metal lathe
By 19brendan81 in forum METALWORK GENERALReplies: 17Last Post: 19th Apr 2010, 09:20 PM
