Results 1 to 15 of 24
15th Jun 2015, 03:46 PM #1Member
- Jun 2009
- Toowoomba QLD
Engineering design question for tandem trailer
I am wanting to make a tandem axle trailer that rides on air bags.
I am not going the traditional route of independant arms like you see on most trailers with air bags or coils springs.
I am going for a setup that will have each bag and the swingarm in a torsion type setup.
I will need to draw a piccie I think that will show what I mean.
But in the mean time, I am trying to work out the diameter of the shaft that will be under torsion, and whether I can get away with mild steel or if I need to go to high tensile.
Is anyone here suitably qualified to help me out here?
I can take a guess but that's it...a guess. I would prefer someone who can crunch numbers for me. I can pay if need be.
Craig
15th Jun 2015, 03:52 PM #2Member
- Jun 2009
- Toowoomba QLD
ok here is my feable attempt at a piccie
Does it make sense?
http://i691.photobucket.com/albums/v...psoa2ksh5l.jpg
15th Jun 2015, 05:10 PM #3Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
15th Jun 2015, 06:24 PM #4Most Valued Member
- 5,942
Hi Surfin,
I'm not a number cruncher, I go from experience and what I've seen else where. From your drawing, the way I understand it, you propose to have a torsion bar assembly at the chassis level, and air bags under the chassis? My question is why would you want 2 types of suspension? I feel that they would counteract one another. One or the other would be fine, look at the Alko suspension system, works well, unless it is over loaded. Ideally for a tandem trailer the suspension should be load sharing, in SA registration of tandem trailer without, won't happen. I've seen a system used on an 80 - 100 series Land Cruiser that had air bags on the rear as load sharing, looked fantastic. A centre pivot point with approx 75 X 50 RHS beam running to both axles with air bags mounted above the axles, nice and simple. Your efforts though may well work, but I like the KISS principle, if it's too complicated there will be problems.
16th Jun 2015, 09:45 AM #5Member
- Jun 2009
- Toowoomba QLD
16th Jun 2015, 09:50 AM #6Member
- Jun 2009
- Toowoomba QLD
The main idea of the design is so that the whole system can be aired down, and the trailer will sit flat on the ground for easy loading of the low car I am building.
When I say it is a torsion type setup, that may not be correct exactly. The air bag mount and swinging arm are sharing the same length of steel at the pivot point, and it will experience a twisting on it (hence torsion) as the suspension cycles.
I spoke to a person last night who I regard highly with his engineering design and he thinks a 40mm mild steel shaft would work ok for this weight of trailer (2000kg max).
Any other comments or opinions?
17th Jun 2015, 10:23 PM #7Novice
- Feb 2012
- mackay
- 17
Surfin,
I spent nearly 3 years designing/thinking of some sort ofairbag setup for my trailer. I really wanted to be able to lower it for loadingand adjust for different weights. The best I came up with was a smaller versionof what is fitted to the average airbag semi trailer, an axle with an arm eachside which is actually a leaf spring to allow for twisting moments of the axleas required. In the end I bought the average roller rocker spring setup becauseit is simple and the loading of the suspension is spread over 6 differentpoints. I'll have to find a different way to load it....
However for your design, from reading between the lines, theshaft your saying is under torsion is not at all under torsion and is just a pivot.Either way, I hope your an awesome fabricator because welding up swing arms tobe straight and strong will be very hard. For the shaft I would envisage less downward loadto be on that shaft compared to the average axle (shared with the airbags) however sideway load would be greater as nowthe wheels have a lever to bend that shaft. Also you have to consider thepossible legal outcomes if something fails in your design causing an accident.
Personally I would run a roller rocker setup but find thesmallest diameter wheels and tyres possible. Also consider drop axles as theymay suit better. Add a tilting drawbar and with the length of the trailer onlysmall ramps should be needed. I ran airbag helpers on my work cruiser ute (4.2tonne loaded) and simply got sick of having to keep adjusting air pressure dueto leaks.
These are just my thoughts, hope they help in your decisions.
Good luck, let us know how you go.
Sean
21st Jun 2015, 08:48 AM #8Philomath in training
- 6,541
Craig, as a general comment every so often someone puts up a post like yours asking for engineering advice. Problem is that if it is answered by someone who does this sort of stuff professionally and it goes wrong they are legally liable (doesn't matter if they did it as a favour or not - the legal view is that they should should know). Unless you pay full tote odds at an engineering consultancy I doubt you will get the level of answer you are looking for.
Having thrown that into the mix, have you looked at the VW Razorback transporters? They drop the tray down while leaving the wheels/ suspension in one piece as far as I can see. Maybe another way to approach your problem.
21st Jun 2015, 09:27 AM #9
Have you seen the Alko suspension system?
Mobyturns
In An Instant Your Life CanChange Forever
22nd Jun 2015, 03:47 PM #10Member
- Jun 2009
- Toowoomba QLD
22nd Jun 2015, 03:51 PM #11Member
- Jun 2009
- Toowoomba QLD
You mean the rubber mounted Alko independant suspension? If so, then yes I have. I need this design to enable the deck to sit totally flat on the ground, to drive a low clearance car straight on. then pump the bags up and the trailer goes up.
Something similar to this, but a different design:
26th Jun 2015, 09:52 PM #12Intermediate Member
- Jul 2009
- Quorn
- 53
- 35
26th Jun 2015, 10:22 PM #13Most Valued Member
- 5,942
ADR INFORMATION
Australian Design Rules (ADRs) now apply to the building of Caravans, Trailers and most trailed vehicles. It is your responsibility, whether you are a manufacturer or a private one-off builder, to conform to these regulations. Our staff at SA Trailer & Chassis Equipment Pty Ltd will be able to help you with general ADR enquiries on Brakes, Suspensions, Trailer Plates, Lights, Wheels, Tyres and Chains etc.
For specific ADR information and copies of the current ADR regulations, please contact the Department of Road Transport in your state.
GENERAL POINTS ON ADRs FOR TRAILERS
BRAKINGSUSPENSIONS
- Trailers up to 750kg Gross Trailer Mass (GTM) - No brakes required.
- Trailers with GTM from 750kg to 1999kg - Brakes required on at least two wheels.
"Efficient" override brakes, electric brakes or power-assisted brakes are acceptable. - Trailers with a GTM from 2000kg to 4499kg - Brakes required on all road wheels.
Must be independent brakes in either electric, vacuum or compressed air-assisted, with control via foot and hand controller from the driver's seat, with a breakaway system to automatically apply the trailer brakes fully for at least 15 minutes should be vehicle accidentally disconnect from the towing vehicle. - Trailers with a GTM of 4500kg and over - Require fully ADR-approved axles with "S" Cam Brakes, Load Sharing Suspensions and Compressed Air Brake Operating and Breakaway Kits.
Kit Approval Numbers supplied on purchase of approved running kits to make registration easier.
- Trailers up to Gross Trailer Mass (GTM) of 1999kg - Can use Slipper, Shackle or Rocker Springs, or Independent Suspensions.
- Trailers with GTM from 2000kg to 4499kg - Require a Load-Sharing Suspension when in tandem or tri-axle configuration.
- Trailers with GTM fro 4500kg and over - Require ADR-Approved Suspension Kits.
Sorry about that I had been misinformed.
27th Jun 2015, 11:16 AM #14Intermediate Member
- Jul 2009
- Quorn
- 53
- 35
Another reference I found, stipulated that load sharing not required if axle trammel distance is less than 1m for tandem, 2m for triaxle and 3.2m for quad's. Doesn't directly say anything about GTM.
One of the best trailer suspension mods I had ever been done was to change a flat bed trailer, which had two axles at about 1.5m apart changed over to single point suspension. Great in the bush.
My own 7x4 tandem, which is due for major rebuild as the floor is rotted out, will also have both axles treated with single point suspension.Cheers,
Dion.
27th Jun 2015, 11:24 AM #15
Following with interest. What are the advantages of variou axle suspension and some pics would be good
Dave TTC
Turning Wood Into Art
Brake controller for tandem trailer
By chambezio in forum TRAILERS & OTHER FABRICATED STUFFReplies: 5Last Post: 11th Jan 2013, 11:05 AM -
Tandem Box trailer questions
By Dan in forum TRAILERS & OTHER FABRICATED STUFFReplies: 11Last Post: 3rd Sep 2012, 12:19 AM -
Tandem Trailer Spring Bushes
By chambezio in forum TRAILERS & OTHER FABRICATED STUFFReplies: 1Last Post: 27th Jul 2011, 10:44 PM -
Tandem Trailer Build
By Bad Fruit in forum TRAILERS & OTHER FABRICATED STUFFReplies: 2Last Post: 9th Mar 2011, 06:39 PM
