Results 1 to 3 of 3
Thread: trailer floor overlap
19th Jan 2014, 09:43 PM #1New Member
- Dec 2013
- Grafton
- 1
Hi, I'm intending to reframe my steelfloored 6 x 4 trailer. I intend using 50x50x2.5mm box for the framework (as it has been given to me) but need to know how much overlap should I have where the floor comes across the edge of the box frame before I weld the floor in place? 10mm, 20mm? I can't seem to find any recommended or standard construction information. It just seems to be do whatever. My current frame is very light 38 x 25mm and has badly rusted which makes it hard to determine how much overlap was used. I will probably make the sides/ends with 25mm box and gal sheet. Any ideas thanks?
20th Jan 2014, 01:33 AM #2Most Valued Member
If you get your floor sheet first and work from that as sometimes sheets vary a bit (depending where they're made) allowing about 20mm either side. When you've got it all made and welded use some sealing compound on all the sheet joints where they over lap to prevent rusting, prime all welded joints before the floor goes on also.
20th Jan 2014, 07:23 PM #3
Firstly, Welcome Jethro.
I gather you'll be using your existing floor, and just replacing the chassis...??
If this is the case, then I'd be looking to use the same perimeter measurements as your existing chassis, otherwise your current axle length and wheel & tyre combination could have clearance issues if you change the chassis width too much.
Also, if you're making a new chassis, then this is now your chance to lengthen the drawbar. If it's a standard 6X4, carrying standard 6X4 stuff, then 75 x 50 x 3.0mm at 1500mm out from the front cross rail will be perfect. A quick rough calculation, tying the drawbar back to the front hanger, should be around 2200mm each side. And if you get an 8M length, you can use part of the 3600mm piece leftover for a heavy duty rear cross rail.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
Replacing rusted steel trailer floor with ply?
By rhancock in forum TRAILERS & OTHER FABRICATED STUFFReplies: 11Last Post: 5th Sep 2013, 10:16 PM -
Trailer floor bangs when walking on it..fix?
By Earthling#44-9a in forum TRAILERS & OTHER FABRICATED STUFFReplies: 2Last Post: 17th Feb 2012, 07:14 AM
